midrange knock on interceptor
Old Dec 14, 2012 | 09:09 AM
Dart_SI's Avatar
i noticed that the past 2 days ive been getting some KR in the mid range. when i go WOT my scan gauge will read 2.9, then it goes to 1.4 at around 5k. after about 5500rpm my gauge shows 0 knock until redline.
any ideas what could be causing this? bad gas possibly? its only done it the past couple days.
Old Dec 14, 2012 | 09:12 AM
prevsrt4owner's Avatar
Did you recently fill up with gas? If so, I'd go with that theory (shitty gas/less-than-optimal).
Old Dec 14, 2012 | 09:37 AM
Dart_SI's Avatar
yea. ive been using base gas lately (gas on fort riley).
i have heard its not the best. other than showing that KR the car runs fine.
Old Dec 14, 2012 | 10:00 AM
Cool. Yeah, it's just this time of the year for crappy gas. I was at Whiteman AFB for four years (Knob Noster, MO), and they only had up to 91 octane (mostly 89). I'm so glad Georgia has 93, lol.
Old Dec 14, 2012 | 11:06 AM
Dart_SI's Avatar
Bump for more opinions.
Old Dec 14, 2012 | 11:11 AM
user 72239's Avatar
Mine has been doing that too. I get at most 2.9 in mid range when the car isn't at optimal temp. I had filled up at Kroger gas prior but I dont know what is causing it either. we only have 91 here
Old Dec 14, 2012 | 12:20 PM
raver0789's Avatar
Is it getting cold in Kansas?
Old Dec 14, 2012 | 01:29 PM
T-Man's Avatar
Sounds like a combination of bad gas and tip-in KR. The drop off you're seeing is the decay rate (it's slow as F on the LNF).
Does it do it in all gears or is it more load specific with regard to 3rd and 4th?
Old Dec 14, 2012 | 01:30 PM
ATLsilverSS's Avatar
This. Im getting some as well. It just got cold as **** here
Old Dec 14, 2012 | 01:38 PM
Area47's Avatar
Rent me! per hour
turn down the bewst
Old Dec 14, 2012 | 01:50 PM
T-Man's Avatar
Originally Posted by Area47
turn down the bewst
Agreed
Old Dec 14, 2012 | 01:52 PM
SSlobalt's Avatar
I thought it was ALWAYS cold in Kansas.............................and windy.
Old Dec 14, 2012 | 02:16 PM
Dart_SI's Avatar
Lol. I turned the boost down a couple psi, put in shell gas and reset the ecu. So far so good. No more kr.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
OrngBalt
Sep 16, 2015 07:45 PM
