misfire at 12k mi
Old Oct 30, 2009 | 11:47 AM
  #51
jarhead's Avatar
Originally Posted by xray_racer
They replaced a fuel injector on mine and it completely fixed the misfire problem. Then a few weeks later they also had to replace one of the coil packs. Cyl #3 was completely shut down.
Glad to see you're car is good now. I think this spring I am going to buy new coils and keep the originals as spares. The coils aren't that expensive I think they were like 43.00 a piece and were the same coil as used in at least one of the n/a cobalts.
Old Oct 31, 2009 | 09:46 PM
  #52
TorqueSSter's Avatar
Question Still not sure which line !
Originally Posted by rukkee
Thats the post i was referring to. Thanks for the info
Originally Posted by ninja44
They don't get dirty, they just remain dry as they don't see fuel. There may be a chance that the intake valves may get stuck open due to the car being new and very tight tolerances. Once the engine wears they will be fine as was said by "gettingausernamesucks". The line is the big one to the left (driver's side) with the pinch clamp on it and covered in the plastic loom.
I tried this tonight - about a 1/2 oz out of a 5. something oz bottle for $ 5.99. Expensive stuff !
The line I used was on the intake, closest to the front of the car, and out in the open - no shroud. It had a green spring clamp on it. It definitely pulls some vaccuum as it was stumble city when I did not have my thumb on the end of the piece of hose I used !
I put about 3 capfulls of the treatment in there , revved it some after the line was back on, and shut it down. We shall see how it does tomorrow, or Monday on the ride in to work.
A picture of the line you, and others have used, would be beneficial but I am hoping since mine went directly into the intake it will work.
I am at 6200 or so, BTW - seems like I first noticed a pronounced power los/ stumble around ~ 4200 , right after I gassed up. I attributed that to bad gas at the time.
I have not felt a duplication of that symptom since then, but the car seemed a little slower and less torquey since then as well.
I figured 6 bux was better than a trip to the dealer - I'd prefer to avoid that where possible - kind of a personal car goal. Last Saturday did not count as I was having the charge pipe recall taken care of, and had the tires rotated while there.
Can anyone supply a pic of this mystery hose ?
Thanks !
Britt
Old Oct 31, 2009 | 11:46 PM
  #53
rukkee's Avatar
You can use either one. I used Number 1 just cause i thought it would get to all 4 ports evenly . But it's a small opening so if you need a bigger one number 2 is larger. When i did it ....I used it like seafoam ....let the engine suck in the fuel system treatment and shut the car off for 5-10 minutes . Then start the car and go for a drive. Mine smoked pretty bad ..... there was alot of carbon smoke for a mile or so.
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
SStevie
Sep 21, 2015 11:37 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Fearedbynone
Sep 4, 2015 10:24 AM
