mods question
Old Feb 27, 2011 | 10:45 AM
reefer_roids's Avatar
mods question
i have recently bought and installed a K&N sri and Injen upper charge pipe. i have no other mods, and a stock ecu. i have noticed a significant decrease in boost from 13-16psi to 5-6psi. is this normal for the LNF? I will try another run when it gets a little warmer, maybe im just paying more attention to the boost gauge than usual. other than that, i have zero complaints, and love the throttle response+ louder sounds coming from the engine bay! keep in mind i realize to maximize performance i need a tune. but this seems to be a significant decrease in performance. thanks in advance.
Old Feb 27, 2011 | 10:51 AM
JacBlackSS/TC's Avatar
you have a boost leak check your couplings on both the intake and charge piping
Old Feb 27, 2011 | 11:01 AM
TheBoss8688's Avatar
Yea somethings off. Mine went from 12-15 psi to 17-18 with intake and charge piping
Old Feb 27, 2011 | 11:29 AM
1SLOLT1's Avatar
Are you getting a CEL?
Old Feb 27, 2011 | 11:32 AM
duf2570's Avatar
i hate cel..my friend here had similar last week(winter goodies) issue...and it was a boost leak...
Old Feb 27, 2011 | 01:15 PM
no sir. not yet..knock on wood.
Old Feb 27, 2011 | 01:21 PM
AndrewSS/TC's Avatar
5-6 psi sounds like limp mode...
Old Feb 27, 2011 | 01:27 PM
07SSYellow's Avatar
Resident Post Whore/Troll
Ya either limp mode cause of fuel trims or you have a boost leak...also check your end tanks on the intercooler there known for cracking....but recheck all your charge pipe couplers and make sure there tight
Old Feb 27, 2011 | 01:33 PM
northvibe's Avatar
probably a leak in the charge pipping. Did you get upgraded couplers for the injen?
Old Feb 27, 2011 | 02:18 PM
no. i thought about getting them at first, but after installing it, i definitely think that its worth getting the upgrade couplers. the fitment is a little off.
Old Feb 27, 2011 | 02:22 PM
northvibe's Avatar
the stock couplers are WAY to short to make sure they dont blow off. Go to siliconecouplers.com and pick up new couplers and tbolt clamps. Will make your life much easier. I installed the injen cp w/ stock couplers...did a hwy entrance...blew a pipe off hahah..scared the **** out of me...limped home and ordered the upgraded ones, never had a issue since.
Old Feb 27, 2011 | 03:08 PM
sounds good, thanks bro.
Old Feb 27, 2011 | 03:22 PM
hey man. im checking out the website and it looks like they have what i need but what are the measurements of the couplers? i just dont want to order the wrong sizes. correct me if im wrong, but it looks like i need 1- 2" and 2- 2 1/2" couplers wide. are the couplers 3" long? i cant seem to find the length, only the diamerter.
Old Feb 27, 2011 | 03:36 PM
northvibe's Avatar
ya the silicone couplers are 3" or so.
1 x 2" for the turbo outlet
2 x 2.5" for the cp to cp coupler and cp to IC
and double those numbers for the tbolt clamps.
Old Feb 27, 2011 | 03:39 PM
awesome thanks bro. now i still have the t-clamps that came with the cp. so i should be good to go right? they are brand new still
Old Feb 27, 2011 | 04:03 PM
Iam Broke's Avatar
If they are indeed t-bolt clamps and not worm screw ones, they'll be fine.
Old Feb 27, 2011 | 04:08 PM
northvibe's Avatar
He pm'd me and we worked it out
Old Feb 27, 2011 | 04:16 PM
Iam Broke's Avatar
That's cool. I remember the Injen pipe on the stock IC plastic fitting was a pain to get a good seal.
Old Feb 27, 2011 | 08:48 PM
northvibe's Avatar
oh jesus the stock injen couplers are short..I mean you CAN get it to work...but you better be precise as hell
Old Feb 28, 2011 | 10:24 AM
for sure dude. these couplers are not meant to work with this cp.
Old Feb 28, 2011 | 10:50 AM
Grishbok's Avatar
Just a tip: When installing silicone hoses or couplers, spray the connecting surfaces with a good healthy coating of hairspray, attach the couplers, let dry for a few minutes. This will help a great deal at ensuring the couplers do not blow off.
Old Feb 28, 2011 | 11:07 AM
CudaJoe's Avatar
you have a boost leak check you charge piping. you dont need to check the intake
oh make sure you installed the MAF in the correct way... that might mess you up.
And 5-6 psi is a significant boost leak. you will throw a code soon. Limp mode is 0psi boost.
Old Feb 28, 2011 | 12:14 PM
tom.g's Avatar
Getting the aftermarket silicone couplers and t-bolt clamps is probably the best $25 you'll ever spend on your car lol.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
