My new tune!
Old Aug 26, 2010 | 11:31 PM
slowstang's Avatar
Originally Posted by raver0789
ok....so back to my question about a 27psi spike for 200 rpm between 3200-3400
Should I be concerned?
While it is a 24psi tune, from 4300 it starts tapering off 23, 22, etc....
Yes and no on the first question. If you're smart about it the car will have no problems with 27psi. If you lug a high gear you will run into problems...ie don't floor the car at 3k in 4th gear or 5th.
The 24psi tune tapering off is normal...it's the small turbo running out of steam with the airflow demand the engine wants.
Old Aug 27, 2010 | 08:53 AM
Ben.Reilly's Avatar
Yes, you should be concerned. If you plan on using your car as a daily driver, something is going to let go soon running that much boost. People on these boards have gone through pistons, clutches, transmission, etc running that kind of boost.
It is just a matter of time.
Old Aug 27, 2010 | 09:38 AM
BYT*SS*TURBO's Avatar
You don't need to run that high of boost but it wont hurt anything. The turbo is efficient over 30psi at that RPM range but as GM Tech's have said, over 24psi will score the walls.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
