Need help.
Old May 13, 2015 | 06:30 AM
Thomas L Edwards's Avatar
Need help.
Is it a must to get a pcm tune when you put on a CAI with the MAF still on the intake?? Please advise.
Last edited by Thomas L Edwards; May 13, 2015 at 06:31 AM. Reason: I didn't want it to seem as I'm in a frantic mood
Old May 13, 2015 | 06:42 AM
LNFTX's Avatar
Yes or your fuel trims are bound to go to shiz
Old May 23, 2015 | 07:26 PM
StrykerCC's Avatar
Is this what you mean by the MAF location?
I am pretty sure the car was tuned when I test drove it, then they flashed it back to stock, so that might explain why I am having issues at high RPM's...
Also, I know this probably isn't the best place to ask, but, with the Injen piping, if I get the ZZP tune, what exactly is it I have to do with the file to move the sensor? The guy at ZZP told me to just go to cobaltss.net, or google it, and I have, and have not found specifics.
Thanks in advance!
Old May 23, 2015 | 07:29 PM
Sl0wbaltSS's Avatar
They will go to shiz but the shiz will still work. No power gains though cause of the learn down.
Old May 23, 2015 | 08:05 PM
ATOMbomb's Avatar
I still have a Cai without a tune lol. Don't even want to know the trims. But like the person said above me, no gains except a nice sound
Old May 23, 2015 | 09:57 PM
SR Tech's Avatar
Thanks in advance!
That is the stock location for the MAF, just tell them you have an Injen CAI, stock MAF location. I don't see a bov on the hot side so why do you want to relocate?
Old May 30, 2015 | 07:39 PM
StrykerCC's Avatar
I don't want to relocate... the options are Injen Intake, or stock maf location. I guess I should just put stock location? I am guessing the extra 10 bucks for choosing injen is for the stuff to move the sensor, but as noted I don't see a BOV.
Old May 31, 2015 | 12:35 PM
Stock maf location would be if you still have the oem airbox. If you pick injen or k&n that just means you have that aftermarket intake installed and the tune can get worked for that intake
Old Jun 1, 2015 | 12:32 PM
09CobaltSS1's Avatar
Stock location constitutes as anything BEFORE the turbo. So, unless specified otherwise by the manufacturer, pretty much ANY aftermarket cai locates the maf in the "stock" location. Relocating the maf involves capping the maf location before the turbo and moving it to another maf pad on the cold side of the charge system, just prior to the TB. This is 100% not needed unless a vta bov is introduced into the system.
Long and short of it, your maf is still technically considered in the "stock" location.
Old Jun 1, 2015 | 06:00 PM
StrykerCC's Avatar
I just want to say I appreciate all feedback you all have taken the time to give. It helps tremendously in making better decisions.
To 09CobaltSS1 specifically, I know it hurts to bring yourself to explain stuff at my level, but I respect and appreciate all your knowledgeable insights and responses to my questions, even if I get made fun of a little in the process! (Re: Turbo ABS Pump)
I am asking ZZP for specifics, I will let you all know what I find out and will post it in the appropriate tuning thread...
Old Jun 1, 2015 | 07:51 PM
No worries man. I give people a hard time here and there, but it's all meant with love. I'm just a sarcastic guy so it's just my way of joking around, even if it does get misinterpreted from time to time. Contrary to some folk's belief, it's actually not at all meant to be condescending.... with the exception of a few of course.
As far as the Turbo ABS Pump thread you had, that one was almost impossible to not have at least a little fun with. You have to admit, that map/gps line was a good one.
Old Jun 3, 2015 | 07:32 PM
StrykerCC's Avatar
From Steve @ ZZPerformance.com
[...] stock location is what you need [with my setup]. [The other options are] for those that are running an aftermarket BOV in the upper charge pipe. To do that, requires moving the MAF to the lower charge pipe.
Old Jun 3, 2015 | 09:39 PM
Why does lint always wind up in my belly button but not my armpits
Old Jun 5, 2015 | 08:55 AM
QuickSilver_SS's Avatar
😄 i know right !!! Somecrazy shiz right there !!
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
twilson380
Sep 14, 2015 10:52 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
