Need help with tranny!!!!ASAP!!
Old Mar 18, 2010 | 04:36 PM
cardelino18's Avatar
ok so we have everything out but the tranny does not want to come out... how do i pull it out?!?!?!?!?!?! o need help ASAP!!!!
thanks!
Old Mar 18, 2010 | 04:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
are you sure you have everything out? make sure the hidden bolt behind the starter is out. lol
Old Mar 18, 2010 | 05:12 PM
xray_racer's Avatar
Like Blazin said, then just give it a good pull! It helps to have someone else to help steady it. Are you using a transmission jack?
Old Mar 19, 2010 | 12:18 AM
yes everything is out and ready now we have a fuking problem the the pin that goes to the top of tranny for the bleeding ****... i dont know whats it called but we cant get that **** in...
Old Mar 19, 2010 | 12:23 AM
ItalianJoe1's Avatar
Did you take the clip out of the aluminum block and take it off? What exactly are you having problems with?
Old Mar 19, 2010 | 12:29 AM
well if you know what im talking about,... its that thing where the break fluid goes into the clutch.... well you know there is two clips that you have to put for pressure...well we CAN NOT put that thing in!
Old Mar 19, 2010 | 02:00 AM
Which one? Did you damage the end of the hose coming from the transmission (where the bottom clip goes)? I had to replace that hose on one car I did. Where is the car? If I came and looked at it I could tell you what you need to do.
Old Mar 19, 2010 | 08:29 AM
Wickedlsj's Avatar
If you haven't figured it out how it goes back in already, the clip goes in from the side/bottom.
Old Mar 19, 2010 | 06:51 PM
we are replacing that freaking clip cuz we broke it and we cant find it anywhere so we are putting steel breaded line and we are customizing the pressure plate to have a breaded line in... thanks for all the help guys!
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Cobe
Sep 19, 2015 11:04 AM
