Need help with tranny!!!!ASAP!!
ok so we have everything out but the tranny does not want to come out... how do i pull it out?!?!?!?!?!?! o need help ASAP!!!!
thanks!
thanks!
yes everything is out and ready now we have a fuking problem the the pin that goes to the top of tranny for the bleeding ****... i dont know whats it called but we cant get that **** in...
well if you know what im talking about,... its that thing where the break fluid goes into the clutch.... well you know there is two clips that you have to put for pressure...well we CAN NOT put that thing in!
Which one? Did you damage the end of the hose coming from the transmission (where the bottom clip goes)? I had to replace that hose on one car I did. Where is the car? If I came and looked at it I could tell you what you need to do.
we are replacing that freaking clip cuz we broke it and we cant find it anywhere so we are putting steel breaded line and we are customizing the pressure plate to have a breaded line in... thanks for all the help guys!
Iceberg
Sep 29, 2015 12:33 PM
