Need some help no boost
I have a 08 turbo that will not biuld any boost. I have checked for leaks and didnt find any. When its cold it will go to 7psi and the the drop off to nothing once it warms up. I tell you one thing these car sux with out the turbo. Feels like im driving a dam go-cart. Any info will help. One other thing i tried is disconnecting the battery and that didnt work.
There are bullitons out for the wastegate seloniod. That could be the problem. There is also a buliton for a bolt that is on the radiator suport rubbing on the charge pipe under the left side of the car (looking at it from the front). Could also be it
Have you looked at the intercooler for leaks. There is a bulleting out on intercoolers deforming and leaking. Check to see that the intercooler passages are parallel.
Oh really, I don't recall seeing this one and I move ever bulletin posted here to our provincial Cobalt forums so there's a central reference...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
