Nitrous Set-up
Old Apr 3, 2012 | 02:26 PM
Area47's Avatar
Rent me! per hour
spraying directly at the maf is bad. you will freeze the maf. the car will lean out, and you will lose a motor. end of discussion.
a dry kit using the maf as a fueling source is fine. fog the maf/air intake tube. this will work a lot better than the crap-tastic thing you have going on.
Old Apr 3, 2012 | 03:16 PM
CudaJoe's Avatar
well Im interested in the results this has. take some runs at the track with and without it and show us what kinda of performance capabilities this has. Also let us know if anything goes wrong that way there is a record on here of how long this setup will last before killing the MAF or the computer makes a wrong calculation.
Old Apr 3, 2012 | 03:27 PM
Chase0224's Avatar
Originally Posted by WannaBFast5
Yes i have purge and yes
might want to re route it under the car. Wont pass tech, plus lines blow, and with it being in the cabin isnt safe.
Old Apr 3, 2012 | 04:52 PM
WannaBFast5's Avatar
Already have some runs on the street to show the difference. Will be going to IFO towards the end of the month and can show the difference there. Also with a Dyno day. I will try to get all info i can. Im pretty sure by now i would see some kind of issues after spraying 20+ times wouldnt I?
Old Apr 3, 2012 | 05:17 PM
jmfselu's Avatar
you never know. number 21 could be the last. or it may never blow. You just dont know.
Old Apr 3, 2012 | 09:41 PM
Area47's Avatar
Rent me! per hour
yes, argue with the guy that has run every type of nitrous setup under the sun since 1997. BRILLIANT DEDUCTION!
::facepalm::
06blackg85ss
83
Jan 18, 2017 04:35 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ncstateredline
Sep 10, 2015 07:22 AM
Brian MP5T
Nitrous Oxide
18
Nov 20, 2005 06:53 PM
