No boost, cel
Old Dec 28, 2011 | 07:32 PM
C_A_D88's Avatar
No boost, cel
So I took my car for a drive, wouldn't boost past 10kpa which I think is 5psi
Shut the car off, started it back up boosts fine, well as much
As I can with snow on the road, but a cel also came
Up when I restarted the car, code was a p0303
Have a treadstone intake
And gms1.
Other then that car is stock performance wise
Old Dec 28, 2011 | 07:51 PM
ATLsilverSS's Avatar
cylinder 3 misfire. p030x means misfire the x will indicate which cylinder. the code will go a way after a few drive cycles or you could clear it with a code scanner. could be many things from bad gas to a bad plug or coil. just keep an eye on things. if it acts up and/or code reappears check things out
Old Dec 28, 2011 | 07:53 PM
Maccoy316's Avatar
It's because you have the GMS1. Is your turbo fluttering when you let off?
C_A_D88's Avatar
Ok so I don't need to worry about the cel unless
It doesn't go away or comes back
And what would cause me to boost to 5 psi and with a restart of the car I can boost normally?
Old Dec 28, 2011 | 07:55 PM
Powell Race Parts's Avatar
go see nate and stay off the forums lol
Old Dec 28, 2011 | 07:56 PM
C_A_D88's Avatar
I don't know what a fluttering turbo sounds like, but sounds normal when the bpv
Goes off, when it happened my radio was turned up, but when I restarted it, sounded normal,
I have forged bpv in the mail , dunno if that will
Help or not tho,
Old Dec 28, 2011 | 07:57 PM
C_A_D88's Avatar
John I don't really have time to see a dealer an hour away
From me, and I need a stock intake
Before I do so any ways
Old Dec 28, 2011 | 07:58 PM
Maccoy316's Avatar
The wiring harness for your GMS1 is probably put together with the plastic caps that crimp down. They like to be cheap. So your connection isn't 100% especially if the wires get bumped with your fan or just normal driving. Best way to make it go away forever would be soldering the wires together then tightly wrapping them with electrical tape. In the mean time you can either clear the code and be good to go or disconnect your battery for about 10 minutes then you will be good to go.
Old Dec 28, 2011 | 07:59 PM
car goes in to limp mode or reduced power mode if the ecu detects something wrong to prevent damage. is some instances when limp mode is triggered, such as a misfire, you can shut the car off and turn it back on and you are back to regular unless another bad misfire is detected and the ecu sends it into limp mode again
Old Dec 28, 2011 | 08:04 PM
Maccoy316's Avatar
The Forged BPV wouldn't fix it, but it will sound nice when you let off IMO. If it happens again try to listen for a flutter. Trust me you'll know when you hear it, because it wont sound like a normal smooth pshhhh noise, instead it'll be intermitted.
Old Dec 28, 2011 | 08:07 PM
C_A_D88's Avatar
And if the turbo does flutter, then what?
Old Dec 28, 2011 | 08:10 PM
Maccoy316's Avatar
It's just another symptom of the GMS1 and it's annoying as F***. I thought a Forged BPV would fix it but it doesn't. It is better than the stock plastic BPV.
Old Dec 28, 2011 | 08:15 PM
C_A_D88's Avatar
Ok I'll have to keep an ear out then, hope the cel goes away
Old Dec 29, 2011 | 12:27 AM
raver0789's Avatar
C_A_D88:
Do not take your car into the dealer with any part other than stock on it. Some dealers are alright, but take it from me, no stock parts. I had a aftermarket downpipe and gms1 and even after the manager told me i could put the downpipe on they voided my warranty. They will flag you. Alot of them are ********. Put all your stock parts on.
The 5psi issue is caused for a variety of reasons. Nate will fix it. The 5psi mode is to protect the car so it's not damaged for whatever reason. I'm not sure what the issue is. Take it to nate.
Cheers and goodluck.
Like powell says don't listen to all the ****.
Old Dec 29, 2011 | 07:54 AM
C_A_D88's Avatar
What if I have stuff that doesn't have
To do with the drivetrain, like twm shifter , head unit, speakers and subs?
Old Dec 29, 2011 | 11:22 AM
brant's Avatar
separate warranties youll be fine
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
DocSvensk
Sep 27, 2015 02:24 PM
