NOS on the LNF
Old Dec 11, 2011 | 09:19 PM
donkeyballs's Avatar
Originally Posted by RyRidesMotox
LOL a 200 shot? that would brake the tires lose at almost any speed lol... No weight over the rear wheels. There is a guy with an LSJ in southern cal here that that runs nos... I don't know how much he is using.
Its a HD 6.0 and i have 10"wide wheels with a good size tire on it lol.. Its so heavy it would probably be a dog.
Old Dec 11, 2011 | 09:22 PM
RyRidesMotox's Avatar
Is it a 2500? Should have went diesel... The Dmax is a beast.
Old Dec 11, 2011 | 09:28 PM
Yes and its a 2000 so its not anything special.. I never got into the diesel trucks but my buddy has a bad ass super duty that's pretty quick.
Old Dec 11, 2011 | 09:32 PM
Haha yea diesels are epic I love em lol but that's just me.
Old Dec 11, 2011 | 09:40 PM
I love the amount of black smoke it puts out If your behind him you have let off and wait for the smoke clear cause you can't see ****.
Old Dec 11, 2011 | 10:58 PM
Haha I love rolling coal too, but that's usually the sign of poor tuning... they shouldn't smoke alot, that just means there is alot of unburnt fuel flowing through. My old diesel suburban never smoked cuz it was really efficient.
Old Dec 11, 2011 | 11:20 PM
Stamina's Avatar
Originally Posted by Fastgti69
Not always, depends how big of a shot. Nitrous is not bad for the engine, it's actually something like meth injection just much stronger. 75 shot is a lot for this engine and turbo. It will max the turbo out and risk blowing that if anything. I'd play it cool with 50 shots.
Not following your thought process there... lol
As far as NOS in an LNF... I have to as, why? Just tune it for more boost, you are doing the same thing (more air in the motor) only safer and more reliably.
That's what I'm saying. That and you never have to keep showing up at race shops to shell out more money to fill up on boost.
Old Dec 12, 2011 | 12:10 AM
2006RedCobaltSS's Avatar
HAHA.. Nitrous was a great time in the Cobalt. Made me *** everytime i sprayed it.
Old Dec 12, 2011 | 10:46 AM
Well I can see it for a non boosted motor... but ours come with forced induction from the factory... Any power you can make on spray you can make by upping boost.
Old Dec 12, 2011 | 12:20 PM
newt's Avatar
Only thing to remember with Nitrous on a forced induction car is the "shot sizez" (HP rating) is alot more, as that is meant for a N/A car.
So a 50shot (50 additional HP) will end up being alot more than 50HP on a turbo car.
I say giver tho, if it is properly set-up nitrous is very safe, problem is most people half ass something together and blow their **** up.
Old Dec 12, 2011 | 02:12 PM
  #36
He has a 5 or 6 tune switch and can make it smoke or **** ton of tq/hp.
Old Dec 12, 2011 | 02:15 PM
  #37
Most t/c and s/c kits on N/a cars are hacked together also. People start with good intentions, buy a kit, realize they don't have the skill to install it, then install it anyways while cutting corners, then blow their car before having it properly dialed in, then come on forums and bitch about how x company makes a garbage x kit and no one should buy it because you can't install it on your car with a toothpick and scotch tape.
Does he have a banks tune system? My buddy's dad has one on his truck... it's all controlled via a PDA attached to his truck.
Old Dec 12, 2011 | 02:17 PM
  #38
OrlandoSS's Avatar
Originally Posted by 05Slowline
orly
404ci Z06 Corvette with 200hp Nitrous kit - YouTube
and op you're a fking straight up flamer, NOSSS NOSSS NAWWWSSSSSSS
it's called nitrous.
Sweet Vette
Old Dec 12, 2011 | 02:24 PM
  #39
I think it is but i would have to ask him.
Old Dec 12, 2011 | 02:31 PM
  #40
ac66bronco's Avatar
I have thought of doing this with a VERY small shot just to have something to wash the valvs with and prevent the DI gunking up the valves.
Old Dec 12, 2011 | 02:40 PM
  #41
Nitro doesn't have the same detergent effect as the stuff they add into pump gasoline, in all likelihood, it wouldn't do a shitting bit of good. you would be better off with a H2O/Meth kit... If you remember from highschool chem class... water is known as the universal solvent. Carbon deposits would be washed off, also the meth would help with that since the alcohol in the methanol would clean the valves... and METH/H2O is cheaper, easier, and more useful on a day to day basis than NO2
Old Dec 12, 2011 | 02:48 PM
  #42
ac66bronco's Avatar
N2O does if it is a wet shot....
True about the meth but then again I dont have a meth kit and i have 2 n2o kits lol
Old Dec 12, 2011 | 02:54 PM
  #43
that's cool... Give it a shot then lulz @ the pun haha... um I would just say meth kit cuz its alot harder to blow your motor to jupiter with a little 2gph water fogger nozzle.
Old Dec 13, 2011 | 04:37 PM
  #44
silverbullet08's Avatar
Originally Posted by yamaha288
maybe silverbullet guy will chime in he has been spraying his for a while now it moves out pretty good dont know what size he spraying though
I have ran 4 bottles through my car. 50,000 miles on it and been tuned since 3k. I do My own tuning so I know how to keep it safe. Its a dry 75 shot. The car comes to life when it gets it. Think about the first time you were tuned... then add that again ontop of your tune. You cant use it unless your doing freeway pulls. I break loose at about 85 to 90mph in third gear when it hits. It does help the IATs during long pulls. The only issue ive had is traction. a progressive style system would work best. The power comes on so hard and fast that it just breaks loose. Not like a turbo that builds the power.
These motors can take a lot if you have a safe tune in them. I spray meth 50/50 alc h20 mix, run 50/50 E85/93, 24-25psi, and the 75shot the majority of the time. You wont over spool the turbo either with a proper tune. If you keep boost reasonable and use the nitrous for the extra power you need then your fine. Then its would be just like adding more volume from your compressor side of your turbo. Nitrous is just as safe as boost. You just have to use common sense and tune for it also just like boost.
Old Dec 13, 2011 | 04:46 PM
  #45
Wet Nitrous shot will clean nothing. If you are spraying a wet nitrous shot with alcohol as the gas from a spare tank then you may get a slight cleaning effect on the intake valves, but not much to notice due to it only getting the alcohol when you spray. On a port syle injection system your injectors spray the intake valves so if you run e85 or alki then you will have much cleaner valves. Meth injection on our cars will clean the exhaust valves and tops of the pistons. Not the intake valves. I know this becaue i have sprayed meth for the past 10k miles after cleaning my intake valves and still had gunk on the valves after taking a second look. the cleaning effect is after it burns mainly.
Old Dec 13, 2011 | 06:59 PM
  #46
Yea but the Meth isn't spraying all the time just like the nitro... If it sprayed more it would probably keep the valves cleaner... but bottom line, fuel has additives in it to clean valves and such, in DI we aren't getting it on the intake side so no cleaning effect.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
