Odd code problem please help!
Old Dec 5, 2011 | 09:11 AM
Balento18's Avatar
Arrow Odd code problem please help!
Hi gang, I had the following codes:
P0101
P2187
P0017
The car could not make any boost as if the wastegate was keept open but the car could move and the idle was just fine (except when you turn on the AC, it had a small variation but the rpm indicator does not move, 900 rpm idle, but the boost gauge alternated from -20 to -15)
A few days later I did a second scan to start the troubleshooting and found that P0017 was gone. I erased all the codes to see witch one came up first and when i start up the car, the car turn on but promptly turns off. I turn the car back on with the gas pedal at 20% the car stayed on, black smoke witch means that the car is too rich, I release the gas pedal and the car turns off. I tried a few times to see if the codes went back on but no dice.
Old Dec 5, 2011 | 09:16 AM
theamericanautos's Avatar
P0101
P2187
P0017
what mods do you have, if any?
Old Dec 5, 2011 | 10:37 AM
Balento18's Avatar
Only a downpipe and a modern performance intercooler, stock program
Old Dec 5, 2011 | 11:20 AM
You might have a bad MAF or O2 sensor but it could also be the stock engine tune. If the pressure drop before/after the intercooler is significantly different than that from the stock ic, it might be skewing your fuel trims. I don't have much experience tho so I could be wrong. do you know where your fuel trims are at?
Old Dec 5, 2011 | 12:51 PM
Balento18's Avatar
I do not know but I will check and let you know
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
