Option B bolt
Option B bolt
I want to install a Catch Can on the two bolts that are used for Option B, but what are you guys using for nuts on those? I can seem to get anything to fit, screw on, etc.
Thanks
Thanks
The stock ones, or u can go to ur taillight and take a nut from the 3 holding it on, take the one closer to the trunk lid bc u can still tighten it with the black hand twisty thingy...take 1 nut from each light, they are the same threading as the 2 pegs in the stock airbox location
I ran into this with my opt. b brackets. They are 10mm, it might seem like they dont fit because the bolts are painted, adding a little thickness. Just "force" them on. It will strip the paint off the bolts a bit but will be fine.
Go somewhere else if you are wanting to know what a catch can does haha
Both are going into the catch can. It is going to run off the nipple to the catch can then leave the catch can back to the line that run to the intake
Last edited by krazycobalt; Jun 5, 2009 at 06:03 PM. Reason: Automerged Doublepost
If you connect both lines to a catch can you'll have the fresh air line pulling in oil vapors rather than fresh air.
Why would anyone want to help you when your calling them an ******* ?
Last edited by krazycobalt; Jun 7, 2009 at 01:06 AM. Reason: Automerged Doublepost
