OTTP stage 2 or 3 transmission mounts
Old Jan 16, 2019 | 06:48 PM
Eddy1634's Avatar
okay so I took my car to my local shop because I couldn’t figure out what was causing my steering wheel to shake at high speeds and causing the car to pull to the right and I was told there was a lot of play in my mounts and was recommend to go with aftermarket mounts by the tech since I have full bolt ons and a tune so I wanted to ask your guys opinion on what I should get stage 2 or 3 and Would it be worth buying there engine mount as well?
Old Jan 17, 2019 | 08:39 AM
jdbaugh1's Avatar
What condition are your lower control arm bushings?
Old Jan 17, 2019 | 02:08 PM
Eddy1634's Avatar
I’m not sure the tech didn’t say anything about them but would that be something worth replacing while I have him replacing mounts
Old Jan 17, 2019 | 02:51 PM
Definitely have the control arm bushings checked.
Old Jan 17, 2019 | 04:29 PM
jdbaugh1's Avatar
Agree^^ Also consider a non-voided rubber or spherical bushing as an upgraded replacement to the stock voided bushings if you do decide they need replaced.
Old Jan 17, 2019 | 04:32 PM
Yep, parts stores carry upgraded moog bushings that are much better than stock. If you want the best of the best youll have to email gloria at powell race shop.
Old Jan 17, 2019 | 04:49 PM
Eddy1634's Avatar
So what should I be looking for to know if my bushings are bad is it noticeable right away just by looking at them or do I check for play in the control arm?
Old Jan 22, 2019 | 07:44 AM
06cobaltss/ss's Avatar
the bushings will be dryrotted some and cracking. 99 percent of the time they are. i have the ottp spherical cabs and all 4 of ottps mounts. the car is solid and not wheel hop. i reccomend them for sure.
Old Jan 23, 2019 | 04:10 PM
buy powell mounts
Old Jan 23, 2019 | 04:24 PM
Either Powell or ottp are good, I was running stage 3 mounts from ottp and his cabs and was pretty happy with them
Old Jan 23, 2019 | 07:08 PM
Eddy1634's Avatar
I got the stage 3 mounts from ottp installed and my car vibrates like crazy bad enough you can hear the vibration and it vibrates all throughout the dash and you can feel it in the gas pedal and the tech said it needs time to break in and that it’s also cause they stiffer mounts then stock in your guys experience is this normal?
Old Jan 23, 2019 | 09:40 PM
For me it was mostly when starting to move only other than that it wouldn't vibrate. There is a way to install them so vibrations aren't that big.
Old Jan 24, 2019 | 02:32 PM
Eddy1634's Avatar
that’s what I’m experiencing mostly while starting to move but at highway speeds it’s minimal vibration
Old Jan 25, 2019 | 04:19 PM
I recommend Powell.
Old Jan 28, 2019 | 11:41 AM
Eddy1634's Avatar
I cant support or recommend OTTP.
I was originally going to buy Powell mounts but every time I’d try clicking on the mounts hoping to get to a page to add to cart it would just refresh the page so I got frustrated with the website and just ordered ottp
Old Jan 28, 2019 | 11:59 AM
The only way to buy from Powell is by email or calling I think. the website is for pure info
Old Jan 28, 2019 | 04:24 PM
email gloria@powellraceshop.com
a lot of the time shes basically as fast as texting
Old Jan 28, 2019 | 06:27 PM
C0balts5's Avatar
Have you checked out the zzp performance ones? They have solid rubber mounts so that they are not as harsh but still have the support you need. And definitely look at the lower control arm business, the rear flat bushings rip and cause wicked torque steer and all kinds of problems. I pressed in moog solid control arm bushings and that helped a lot.
Old Feb 15, 2019 | 06:12 AM
Eddy1634's Avatar
Well now I know for next time thanks I thought something was up with the website and as far as the zzp ones i read some threads saying not to go with those and to go either Powell or ottp.
Old Feb 15, 2019 | 03:42 PM
Powell is the best money will buy, it is track tested and proven and the owner helped design parts with GM Performance. No other vendor can back that up.
Old Feb 15, 2019 | 05:05 PM
Wind's Avatar
Dam never knew that was a thing lol.
metroplex
Jun 30, 2016 05:43 PM
PenguinPIE
Mar 23, 2012 01:47 AM
Josh@ottp
Jul 23, 2010 07:16 PM
