over revved the engine :(
Old Mar 30, 2012 | 08:25 PM
  #126
BlackLsCoupe's Avatar
man all of this has reminded me that i need to check my lash adjusters.
Old Mar 30, 2012 | 08:42 PM
  #127
40rty's Avatar
yep
Old Mar 30, 2012 | 08:51 PM
  #128
Dart_SI's Avatar
Originally Posted by 40rty
That sounds right, I mean where else is the exhaust going to go? I at least had one more exhaust valve still working, so exhaust still routed out of the cylinder, just not as efficiently. Did you check the top of the pistons and in the chamber?
no, i have nothing to check that with right now.
based off of looking, the exhaust came out of the intake valves when they opened and went into the #4 cylinder, which is why 3 & 4 were misfiring like mad. 1 and 2 very little to no soot whatsoever.
1 and 2 only have 1 exhaust rocker, 4 has both, so thats probably why the exhaust gas rerouted to 4.
also explains why my map sensor went bad instantly.
also when i had to drive the rest of the way home (so painful) there was no smoke and my afr's were crazy. theyd go normal ish when the car wasnt misfiring, then go really lean once it was misfiring. the misfiring was due again, to the exhaust in the intake manifold.
so far the last things to do is a compression test and to inspect the cylinders, which i dont have the tools for without removing the head (would like to avoid removing the head if i can)
im willing to bet on a higher compression motor, such as a k20, you would blow your piston rings when both exhaust rocker arms fall off.
looks like a really good seafoaming is in order once i get new rocker arms installed.
also i took out the lash adjusters and they all appear undamaged.
keeping fingers crossed that my bottom end is ok and my compression is ok.
so how do you do a compression test? lol. never done it.
Old Mar 30, 2012 | 09:19 PM
  #129
FasterIsBetter's Avatar
I'm still worried about your engine. You have to think, by the time your exhaust has exited through the intake, your engine is on the completely wrong stroke....just because it exited through your intake doesn't mean you're safe. Sorry to be the bearer of bad news, man. I hope it works out as just the rockers being off though and that your rings are fine.
Old Mar 30, 2012 | 09:28 PM
  #130
Boosted4's Avatar
https://www.cobaltss.net/forums/2-0l...isfire-273258/ Second post by IamBroke
Old Mar 30, 2012 | 09:46 PM
  #131
06 GM CobaltSS's Avatar
Damn Dart, sorry to hear what happened. Even the best make mistakes, good luck with the rebuild.
Old Mar 30, 2012 | 09:50 PM
  #132
Dart_SI's Avatar
True. Ill look tomarrow. Im hopeful tho.
Old Mar 30, 2012 | 11:02 PM
  #133
tomj77's Avatar
ya i gotta do that to. frick.
Old Mar 30, 2012 | 11:09 PM
  #134
Dart_SI's Avatar
luckily if those are broken they arent hard to fix.
Old Mar 31, 2012 | 06:12 PM
  #135
Dart_SI's Avatar
update:
snagged some rocker arms and replaced them. reassembled the car and started her up.
afr is fine
exhaust sounds exactly the way it did
no more loud ticking
no stuttering
drove her around the block no problems, even got into a little boost, no problem
going to go out cruising tonight and ill do a few pulls to make sure all is well.
if all is well ill return any donations, im really thankful for all the help guys
Old Mar 31, 2012 | 06:22 PM
  #136
Frogstofall's Avatar
Compression test!!!
Old Mar 31, 2012 | 06:26 PM
  #137
Dart_SI's Avatar
Going to autozone now. Lol. With my car
Old Mar 31, 2012 | 06:27 PM
  #138
Good man!
Old Mar 31, 2012 | 06:29 PM
  #139
vahdyx's Avatar
Damn dude, that sucks. I'll have to send you a few $ when I get the chance, PM me your paypal. I hope it works out buddy!
**Edit** read more of the thread
I'm glad it's working out bro!
Old Mar 31, 2012 | 06:33 PM
  #140
Cobalt_SSTuner's Avatar
Make sure you check your valves on the ones with the bad rockers...but if the valves are f'd up, you'll know when you do a comp. test.
Old Mar 31, 2012 | 06:49 PM
  #141
Dart_SI's Avatar
im doing a compression test tonight.
car still spins almost all the way thru 2nd in 85 degree heat tho.... lol. im so happy
Old Mar 31, 2012 | 06:55 PM
  #142
Blowncavy's Avatar
Thats just mean you need better tires
Dartsi tire fund ASAP
Old Mar 31, 2012 | 06:58 PM
  #143
Dart_SI's Avatar
lol. 255 35 18 nt555's at 30 psi is pretty good tires. (tire psi not boost)
Old Mar 31, 2012 | 08:11 PM
  #144
Iam Broke's Avatar
Hope the compression test turns out ok man. I don't get over here much anymore but hope all is well.
Old Apr 1, 2012 | 12:06 AM
  #145
Knightwolf's Avatar
Oh God.. 6 pages.. I ain't reading all of that lol
However, I know that sound, but yours is worse. You have at least 2 rockers lying around on the top of your head, but I would guess 3. You also have a blown map sensor, which I think you mentioned. You will need upgraded springs at the very least and most likely new lash adjusters to replace the broken/damaged ones. I had mine fixed once under warranty at the dealer, but it went again a month later with no over-revving so I attributed that to the valvetrain being weakened from the first over-rev.. same damn thing you did too btw. I upgraded to a ported ZZP stage 1 head.. it's pricey, but it's well worth it. Your bottom end is probably ok, and actually your valves are probably okay too.. it sounds worse than what it really is.. just keep your fingers crossed lol. I had to finish mine off the first time so I purposely popped that 2nd lash adjuster to make the CEL come on so GM would even look at my fkn car; I think the 2nd one fried my Map sensor as well and that's most likely what threw the CEL. They're retarded around here lol.
I also thought my engine was fubar.. but it's 95% just your valvetrain.. there is a small chance you fried a valve but I doubt it.
Good luck dude
Old Apr 1, 2012 | 12:30 AM
  #146
Dart_SI's Avatar
Good luck dude
your pretty on to what happend. i had 4 rocker arms laying around and 0 broken lash adjusters. both exhaust rocker arms were off so i was misfiring like crazy. the exhaust would vent out of the intake valves when they opened and flow into cylinder 4 because its the only one that has both exhaust rocker arms.
the exhaust in the intake mani fried my map sensor.
so far so good, i took her out for a good cruise and she runs good. i still gotta do a compression test tho.
Old Apr 1, 2012 | 12:31 AM
  #147
sponge14's Avatar
Good luck dude
If you posted this without reading the thread, you made a damn good guess lol.
Old Apr 1, 2012 | 08:49 AM
  #148
Cobalt_Daddy's Avatar
Old Apr 1, 2012 | 09:01 AM
  #149
Dart_SI's Avatar
Sorry guys, I just got a red cross message, my mom in law is in the ICU. she has bacteria in her blood and blood clots in her kidneys and liver.
If its not one thing its something else.
Anyway im going on emergency leave now.
Ill get a compression test done later, I just have different priorities now.
Old Apr 1, 2012 | 09:07 AM
  #150
super08silverSS's Avatar
Sorry to hear that.. best of luck
