P0107....Again but this time....
Hey I know there lots of post about P0107. Here in PR were having this problem. My friend had his Map sensor replaced about a week ago. And 7 to 8 days later. P0107.....dealer s claiming block catalitic converters.....what yall opinion....the car has about 15000 miles
what kind of car, does your friend have an aftermarket intake or anything else done to his car. and at 15,000mi the cat shouldn't be clogged unless the car has been running extremely rich for a long time and you would get a code for catalytic efficiency as well. but give some info on the car and maybe we can help ya a little more.
his car is stock (just got some tune but then got back to stock tune) they have blown lots of map sensors, specialy that guy.
i can tell you have to fix it if you buy me some drinks while we see the fire outside my house :P
lol
ps: tengo mi carro de vuelta
y darwin le puso los puntos y ahora casi no vibra
estoy mas feliz que un pato con dos culos
lol
I have a couple questions regarding this code because I just got it yesterday. Its just the sensor that needs to be replaced correct? Also how long can you go driving with this CEL on? What exactly is the sensor not working doing to my car if it is doing anything bad?
Gaby: Que bno tipo.....
Se apago el fuego ya??
The car is stock....we had the infiniboost tune... our map sensor went off....we all reflashed stock had it replaced....and his blew a week after....but were all still stock....luckly only 3 cars the map sensor blew the other one stayed ok
we thought of buying downpipes and the gms1 kit after the infiniboost once again to see what happends
Last edited by SaleenFreak; Oct 24, 2009 at 08:26 PM. Reason: Automerged Doublepost
Anytime the MAP sensor signal is low the vehicle will likely have a very difficult time starting. Other symptoms may include:
Hard to start
Long cranking times
Sputtering/missing
Blowing black smoke
Poor fuel economy
Dies intermittently
MIL(Malfunction Indicator Lamp) illumination
Causes
The causes of a low MAP sensor signal circuit (P0107) could be any of the following:
Bad MAP sensor
Open or short in the signal circuit
Open or short in the 5 Volt reference circuit
Ground circuit open or shorted
Bad PCM
nada chillin y tu
Yeah was running on infiniboost till map sensor popped....not literaly p0707......and................my friend has a new computer.......was installed the same day as the map sensor...the car stock was boosting 20 psi on some ocasions
Man I have seen numbers ranging from 290 whp to 335 whp and 340 wtrq to 404 wrtq with that tune no real rhyme or reason. Very inconsistant numbers. Dyno's do read differently but not that much. Mods make a difference but again most have similar mods.
well I personally blame that to the weather here....i was making like 29psi which is the reason my map sensor died. I retuned today...same tune and my car is only boosting now to 20 psi(im saying about 270-280 whp probably and probably 290 to 310 wtq................................hope i don't get the p0107 troobleshoot code again
Staged07SS
Jul 12, 2016 09:14 AM
slapbetcommissioner
Oct 1, 2012 05:54 PM
turbosmart4
Jun 15, 2012 07:42 PM
