P0113 Code
Old May 19, 2012 | 09:44 PM
07SSYellow's Avatar
Resident Post Whore/Troll
P0113 Code
alright so i took my car in to get a KY Stage 3 clutch installed, as i put it in reverse at the shop i threw a CEL for the IAT Sensor High Voltage, my IAT sensor was reading -40 degrees. So i researched it and found out it was in the MAF so i replaced the MAF and still have the code. Any ideas what it could be? Think when they did the clutch they messed something up?
Thanks
Joe
I have a K&N Intake(cleaned the MAF as well no Oil on it at all)
Old May 19, 2012 | 10:02 PM
QuickSilver_SS's Avatar
Im just going to throw this out there as a thought and or suggestion. But when the shop I had did my clutch in my lsj a while back. Some how one single wire from my wiring harness got stuck in between the engine block and the bell housing. It caused one of my fuses to blow everytime as soon as you put a new one in. I forget which on. But it was important. So they pulled the wire out once they figured it out, And fixed the problem. Maybe something similar happened to your maf sensor wires ? Just a thought.
Old May 20, 2012 | 01:00 AM
Zander916's Avatar
^^^ This
I DID have something happen to my MAF sensor wires. I don't recall the code it threw but they had to put a new MAF sensor plug on. I could see bare wire on one where it had rubbed the side of the plug.
Old May 20, 2012 | 01:03 AM
Maven's Avatar
youve most likely got a IAT wire broken or crushed and shorted to power. Guys really need to stop just throwing parts at things.
Old May 20, 2012 | 03:44 AM
07SSYellow's Avatar
I've had my MAF go out before, and i didn't buy a new one lol i just swapped the one off my brothers car to see if it changed at all, no change
Old May 20, 2012 | 03:50 AM
jarhead's Avatar
Ya I remember that I was trying to help all the codes pointed to the maf and ended up being the BCM was bad last time huh Joe.
Old May 20, 2012 | 03:57 AM
07SSYellow's Avatar
ya haha stupid BCM!! hopefully this sing another BCM issue, but good thing is my car is still under warranty so ill probably just take it to the dealer on monday
Old May 20, 2012 | 06:44 AM
SSlobalt's Avatar
Are you saying your research led you to find the IAT sensor was in the MAF sensor? I don't understand from the wording, but that's what it sounds like.
Old May 20, 2012 | 07:59 AM
Chevycobaltss3's Avatar
Iat1 is in maf iat2 is in lower charge pipe tmap
And I say wiring
Last edited by Chevycobaltss3; May 20, 2012 at 07:59 AM. Reason: Automerged Doublepost
Old May 20, 2012 | 09:22 AM
Edubs's Avatar
Just take it to whoever installed the clutch and make them fix it. It's very rare that you have a coincidental check engine light after a major install the second you pick it up...
Old May 20, 2012 | 12:29 PM
07SSYellow's Avatar
i know thats what i said! thats why I'm taking it to the dealership, and once they tell me it was done during the clutch install i shall go to the shop with proof and make them fix it
Old May 20, 2012 | 01:12 PM
YelloEye's Avatar
Make sure you keep a receipt from the dealership so the shop you take it to can pay for the diag costs. I'd honestly just take it back to that shop and tell them to fix it.
Old May 20, 2012 | 03:12 PM
vahdyx's Avatar
Hope you get it worked out man! How are you liking the clutch on a side note? You can PM me instead if you want
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
