P0299 :/
Old Mar 21, 2012 | 03:17 PM
yellowss7590's Avatar
P0299 :/
Installed zzp intercooler, zzp charge pipes, k&n Sri, and forge bpv put yellow spring in, car was stock except for trifecta tune 21 psi can anyone help lol
Old Mar 21, 2012 | 03:20 PM
Gremlin85's Avatar
Common wastegate issue...
#09-06-93-004: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator) - (Jul 21, 2009)
Subject: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator)
Models: 2008-2009 Chevrolet Cobalt, HHR
2008-2009 Pontiac Solstice GXP
2008-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
with Engine RPO LNF and LDK (Europe)
Please Refer to GMVIS
Condition
Some customers may comment that the SES light is on. Upon inspection, you may find DTC P0299 (Turbocharger Engine Underboost) or P0234 (Turbocharger Engine Overboost) set.
Cause
This condition may be caused by a mis-adjusted wastegate.
Correction
Note: The wastegate adjustment is sometimes a very fine process. When adjusting the wastegate, only small adjustments should be made. Loosen one nut at a time and only adjust the nut one turn at a time; then tighten the other nut against the shaft and test drive to verify. This may have to be performed several times to achieve the desired boost level. To ensure proper adjustment, the vehicle should be at full operating temperature when testing. The vehicle will be very hot and may need to cool between adjustments. Too large of an adjustment can cause repeat DTCs.
Adjust the turbocharger wastegate. Refer to Turbocharger Wastegate Actuator Adjustment in SI.
Troubleshooting Tips for DTC P0299 - Turbocharger Engine Underboost
To increase boost, adjust the nuts (in) towards the actuator; in essence making the shaft shorter.
Troubleshooting Tips for DTC P0234 - Turbocharger Engine Overboost
To reduce boost, adjust the nuts (out) towards the end of the shaft; in essence making the shaft longer.
Old Mar 21, 2012 | 03:27 PM
Could the yellow spring cause it?
Old Mar 21, 2012 | 03:35 PM
Gremlin85's Avatar
I've never heard of anyone having an issue with either spring from the Forge BPV kit... so I'm doubting it.
Did this happen directly after you installed it?
Old Mar 21, 2012 | 03:36 PM
Yea right after I installed everything maybe tune related
Old Mar 21, 2012 | 03:48 PM
Gremlin85's Avatar
You got the tune at the same time, too?
Swap out the spring to see if that helps. If not it might still be the wastegate actuator as it might have become misadjusted while tuning and driving around.
Old Mar 21, 2012 | 03:55 PM
SunburstSS's Avatar
Not sure on this, but i read somewhere about people installing the spring incorrectly and getting problems
Old Mar 21, 2012 | 04:01 PM
Gremlin85's Avatar
I was just thinking the same thing... or installing the BPV upside-down..
OP, is the opening for the BPV you stalled facing up or down?
It needs to face down.
Old Mar 21, 2012 | 04:34 PM
To the side lol
Old Mar 21, 2012 | 04:39 PM
Gremlin85's Avatar
Originally Posted by yellowcobaltss7590
To the side lol
Explain.
The slot should face towards the ground when installing the BPV to the turbo.
Old Mar 21, 2012 | 05:03 PM
You mean the fitting where the vacuume line connects to?
Old Mar 21, 2012 | 07:33 PM
SSlobalt's Avatar
On the forge, there is a hole in the side of the plunger bore. Face that downward. See pic below to understand why.
damastah
May 23, 2013 11:29 AM
rukkee
Sep 21, 2011 05:49 PM
Mike_peperni
May 25, 2010 06:15 PM
SportredSS
Mar 17, 2009 11:32 PM
SportredSS
Mar 15, 2009 11:46 PM
