P2101 and p0606. Help
Old Feb 14, 2018 | 01:50 PM
tuned08ss's Avatar
Well I just got these two codes for the second time. They are not allowing the car to stay running or start at all really. Got them originally a week ago on start up and cleared the codes. Started right up. Been a week or about 100 miles and now the codes are back with the same symptoms. Rough idle to no start. I've read that it has to do with the ECU and throttle position. I'm not sure where to go from here because by clearing the code the car instantly goes back to starting and driving normal. Any ideas? 2008 lnf with hp tune, cbe, ic, and dejon Sri.
Old Feb 14, 2018 | 02:59 PM
Henry3959's Avatar
What have you temps outside been like?
Bring the PCM indoors and let it warm up. PO606 usually act up in colder weather. Reinstall the warm PCM and see if that make a difference in getting started.
Every PO606 I have seen requires a replacement.
Old Feb 14, 2018 | 03:02 PM
if its coupled with another code, go after that code first. I can almost guarantee that fixing the P2101 will take the P0606 with it.
Old Feb 14, 2018 | 03:17 PM
tuned08ss's Avatar
It's been about 35 to 40 degrees lately. I just wonder why when I clear the code the car runs fine? It's weird.
Old Feb 14, 2018 | 04:05 PM
umrdyldo's Avatar
P2101 should be the throttle body or the connector to it.
P0606 Could spell trouble. Possibly a bad ECM.
Old Feb 14, 2018 | 04:10 PM
Henry3959's Avatar
Not weird... It looses the enable criteria it saved and has to see it again, which for this code is near instant since it is a continuous monitor code.
Old Feb 14, 2018 | 04:13 PM
while it is a possibility that its the ECM, it is very unlikely.
Likely to be the TB or wiring
Old Feb 14, 2018 | 04:19 PM
Henry3959's Avatar
When it won't start, does it even crank over? PO606 should disable crank mode.
Old Feb 15, 2018 | 12:15 AM
tuned08ss's Avatar
Yea it turns over but won't stay running. It chokes and then eventually shuts off. Basically it stays running for about 4 seconds
Old Feb 15, 2018 | 08:41 AM
Henry3959's Avatar
Start with the P2101 then. The PO606 disables cranking.
If you throttle body has the thin plastic side cover, find a good one to try. Do not attempt to clean it before trying it. They hate solvents getting inside.
Old Feb 15, 2018 | 09:09 AM
In my experience, if you let the ecm go to sleep after p0606 sets, the car will restart. Usually about one minute i think.
Old Feb 15, 2018 | 09:18 AM
Henry3959's Avatar
Yup... also varies by platform
Old Feb 15, 2018 | 02:24 PM
tuned08ss's Avatar
What do you mean by sleep?
Zzp has the throttle body for $70. Should I just start there?
Old Feb 21, 2018 | 09:20 AM
You can test/diagnose wiring and parts before just changing them. That would be the free/smart way to do things.
Letting the car go to sleep means you remove the key, open and then close the drivers door, and wait about a minute. After this time, all the modules in the car go to a "sleep" or low power state.
Jbishop0352
Apr 21, 2017 10:25 PM
Shanman
Jun 18, 2016 07:00 PM
sternerG85SC
Jul 29, 2012 02:14 AM
MastaShaKe_88
Jun 9, 2012 03:16 PM
Jmc007
Feb 10, 2006 10:46 PM
