p2187 question
p2187 question
Ok so i installed a BNR2871 on my car and every now and then i get p2187 lean at idle dtc. did some searching and found that its most likely the hose that used to bolt to the factory turbo. being that there is no spot anymore on the BNR the hose is just dangling and probaly causing some sort of leak. now i went to my local parts store and found this:
you think this would work instead of getting a nipple welded?
the line isn't going back into the intake manifold. i need it to go back into my dejon sri. i figured that this would work cuz all it is is unmetered air that needs to go back in the system so i can get rid of this lean code. i'm just going to try it. whats the worst? i gotta get a bung welded anyway?
Iceberg
Sep 29, 2015 12:33 PM
