P2227 code problem
Old Oct 29, 2018 | 02:48 PM
Robhuckell@gmail.com's Avatar
P2227 code problem
I know there’s tons of threads on this, but I havnt been able to find any like mine. I bought a 2009 cobalt ss turbo that has been tuned, when the engine light is on I get no reading on a baro on my RPD, I noticed in first gear it’s boost limited but second will peak 21-22 psi and hold about 20, but 3,4,5 wouldn’t hold more than 12psi. And I had that terrible flutter after I let off the gas lightly, so just to see what would happen I cleared the engine code (p2227) and it builds full boost in every gear and no flutter, rpd also reads. I’m not sure if it good to just keep clearing the code? The last owner tried to have it fixed but I’m not sure what to do
Old Nov 8, 2018 | 08:48 PM
tomj77's Avatar
If ur getting a baro code....either bad tune or ur ecu needs replacing since baro sensor is built into ecu
Old Nov 24, 2018 | 07:00 PM
[QUOTE=tomj77;7702154]If ur getting a baro code....either bad tune or ur ecu needs replacing since baro sensor is built into ecu[/QUOTE/
do you think gms1 sensors would make a difference? I thought the baro sensors were the map sensors? Have I been mis informed? My baro sensor works when the engine light is cleared since I do have an accurate baro reading on my rpd so could it just be the tune?
Old Jan 8, 2019 | 06:39 PM
I figured out what it was, some bone head before me put stock maps on a gms1 or 2 tune, going to get a custom tune for the stock sensors and that should fix it!
Nov 26, 2018 06:20 PM
Tuning
Oct 16, 2018 11:37 PM
stevenwhaley89
Jul 7, 2015 09:17 AM
maccos
Aug 3, 2014 01:23 PM
knapster6
Nov 15, 2011 03:55 PM
