Percision 5457RB Turbo Swap Complete!
Old Mar 3, 2009 | 12:57 PM
  #176
robster180's Avatar
Originally Posted by Terminator2
When you rev above 6500 RPM or so the injectors no longer have enough time to inject the necessary amount of fuel in to keep the A/F ratio where it needs to be. The computer tells the injectors to spray for longer and so the injection cycle carries over into the compression stroke. That wets the heck out of the piston and causes the combustion flame propegation to go to hell. Basically the motor breaks up and runs like crap and power falls off badly no matter what you have in the way of mods.
Ohhhh Ahhhh, that explains it, seems like this dude isn't running into injection problems pushing 400+ whp, but thanks for explaining
Old Mar 3, 2009 | 12:58 PM
  #177
Terminator2's Avatar
He would not be making those numbers if he wernt running 26 psi and meth injection.
Old Mar 3, 2009 | 01:02 PM
  #178
robster180's Avatar
gotcha, so pushing more boost helps as well as meth injection helps the injection to a certain point
Old Mar 3, 2009 | 01:06 PM
  #179
Yes, once, if, the GM stage kit comes out in will enable us to run up to 3 bar total pressure instead of 2.5 bar that will help power if you are running a bigger turbo, but it still does not solve the injector issue. Someone will need to find a way to modify the stock injectors so that they spray more fuel during the avaliable injection window. Once someone does that there will be the potential for 500+ whp LNFs.
Old Mar 3, 2009 | 01:18 PM
  #180
FF_ace's Avatar
he put down 410whp and 390wtq at 22-23 psi couldnt turn up the boost cuz the stock spark plugs were blowing out. thats really good #'s
Old Mar 3, 2009 | 01:23 PM
  #181
It looked like 26 psi on the dyno graph log i dunno. He had the maps clamped so he could run those pressures if he wanted to.
Old Mar 3, 2009 | 03:17 PM
  #182
FF_ace's Avatar
he has a thread up on another LNF forum also and stated the maps were clamped but only pushing 22-23 cuz the stock plugs were blowing out he wanted to go up to 26.
Old Mar 3, 2009 | 06:01 PM
  #183
08BlackSS/TC's Avatar
Come this Spring/Summer BTF already has a GT4094R going on his GXP along with a secondary fuel rail
Hello BIG numbers!
Old Mar 3, 2009 | 06:25 PM
  #184
boostking's Avatar
the 37x hp numbers were spiking to 25psi and dropping to 23psi. THERE WAS NO METH ON THIS CAR AT 410whp AND THIS WAS ON 22-23psi.
Old Mar 3, 2009 | 07:24 PM
  #185
Area47's Avatar
Rent me! per hour
proof or shens.
Old Mar 3, 2009 | 10:20 PM
  #186
Originally Posted by Area47
proof or shens.
Me or boostking?
PM me for pics.
Old Mar 4, 2009 | 08:13 AM
  #187
boostking's Avatar
proof or shens.
....... my dyno graph of 410 doesn't have boost on it.... not sure why I would lie about it... I have given all TRUE info about my build why would I lie about boost. anyway the kit is sold and I'm sad......
but I will def. still be on the forum.
Old Mar 4, 2009 | 03:02 PM
  #188
USMCFieldMP's Avatar
Rattlesnake Race Shop
He also dyno'd on a Dynapak that gives very high numbers.
My Stg2 w/ 2.8 and Intake and exhaust put down 263/238 on that dyno.
So his true numbers are probably closer to 370-385.
A friend of mine dyno'd his stock 2007 GT500 there and put down like 490hp.
Old Mar 4, 2009 | 03:17 PM
  #189
boostking's Avatar
lets not compare numbers from dyno to dyno the car did just as much on a dynojet was well. thats not the point of this thread. anyway thanks for all the support and I will see you all at a local track.
Old Mar 4, 2009 | 03:27 PM
  #190
I dyno'd on the same exact dyno. It gives high numbers. That is how my friend put down nearly 490whp on a 500hp car.
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
ThoR294
Oct 4, 2015 08:44 PM
maliki778
Oct 1, 2015 07:39 PM
