Percision 5457RB Turbo Swap Complete!
Old Feb 16, 2009 | 02:54 PM
  #126
Terminator2's Avatar
[QUOTE=06black;3476377]then this Steve you speak of is an idiot.
He is talking about Psychostevo, or "Steve", is a well respected member of this community and has tuned many LNF cars, but not many with big turbos though because there are not many to speak of yet.
Old Feb 16, 2009 | 02:56 PM
  #127
R&C_rallySS's Avatar
Originally Posted by boostking
Today I went to Dejon Powerhouse and finshed my turbo swap! All I can say is WOW!
Though the tune is still under developement the car really feels strong! Here ar some specs on the turbo and related parts.
Percision 5457rb (its percision new "50 trim" replacement)
500hp rated
T31 series with better spool and less back pressure = more HP!
"54 refers to the compressor inducer
dia. and 57 to the turbine wheel inducer dia. It uses their latest billet
turbine wheel which is more aerodynamic for faster spoolup. R is for ball
bearing center-section and B is the compressor cover."
Full Kit Info will be aval. soon. Pics Monday!
That is great, I'm about ready to do a turbo upgrade on my Syclone once I sell my balt. I'm going with a 74 GTQ with S cover turbo. 74mm turbo with a .82 A/R. Massive turbo for 750hp! Good luck with your cobalt build man! turbos rock BTW Percision > everything!
Old Feb 16, 2009 | 03:08 PM
  #128
06black's Avatar
[QUOTE=Terminator2;3476458]
ahh, that steve.
cant believe i dident put 2 and 2 together there.
now things make since.
Old Feb 16, 2009 | 03:22 PM
  #129
[QUOTE=06black;3476535]
Originally Posted by Terminator2
ahh, that steve.
I take it you dont like steve for some reason.
Old Feb 16, 2009 | 04:14 PM
  #130
06black's Avatar
i never said any thing of that matter.
Old Feb 16, 2009 | 04:20 PM
  #131
Oh, it is hard to red people's emotions online. It just sounded to me like you had some kind of issue with him when you said it all makes sense now I guess to ment that you realize who Boostking is talking about. BTW you are knowledgable in this area why dont you suggest something to him that he may have overlooked becasue if the intake cam advance did not work I know of no other ways to get a faster spool.
Old Feb 16, 2009 | 04:32 PM
  #132
elecblue06's Avatar
... certain people think that meth wont help these cars too ...
not to mention advancing cam timing should work ... ... theres NO reason he should have that much lag... tuning can definitely take care of that
there are people that have bigger turbos ... with a better spool
Old Feb 16, 2009 | 04:35 PM
  #133
USMCFieldMP's Avatar
Rattlesnake Race Shop
We'll see how mine spools.
Old Feb 16, 2009 | 04:40 PM
  #134
elecblue06's Avatar
hehe that'll be interesting.. i thought you were trading that bish in
Old Feb 16, 2009 | 04:41 PM
  #135
He said he already tried the intake cam advance that had been suggested to no avail. I am stumped too as synapse motorsports gained some serious mid range power by cam tuning their GT28R kit.
Old Feb 16, 2009 | 04:44 PM
  #136
elecblue06's Avatar
exactly... why would it work for a few other turbos but not this one... it worked for the 3071 car that 06black tuned if i remember correctly as well
Old Feb 16, 2009 | 04:59 PM
  #137
I dunno. Unless he has too much intake cam advance that would cause the intake valves to open too soon before all the exhaust gas has escaped that would cause some issues. I think he just needs to find the correct balance of intake cam advance, A/F, and ignition timing for his setup so that it will build compression sooner. That will take some trial and error because as far as I know he is the only LNF with this setup.
Old Feb 16, 2009 | 05:01 PM
  #138
elecblue06's Avatar
I dunno. Unless he has too much intake cam advance that would cause the intake valves to open too soon before all the exhasut gas has escaped that would cause some issues. I think he just needs to find the correct balance of intake cam advance, A/F, and ignition timing for his setup so that it will build compression sooner. That will take some trial and error because as far as I know he is the only LNF with this setup.
thats correct it's a balance
Old Feb 16, 2009 | 06:58 PM
  #139
boostking's Avatar
any person for that matter, who thinks they have the knowledge to comment on the tune of this motor all while saying that cam timeing (phase) will have little to know effect on boost response is part of the growing group of people whom need to stop talking. educate ones self.
cam phase dictates air flow across the head, manipulate this to achieve max cylinder fill while running a late spark event along with the ext valves open will jump egt's witch will in turn add to boost response in a vary quick manor.
as for suggestions, its not my job to fix your set up. i engineered mine for a good long while, and its delivered amazing results.
i suggest you do the same. educate ones self for best results. relaying on other people will get you mixed reviews and an uncertain future.
your hotside is NOT the issue. that's a tiny guy.
I'D START PLAYING WITH THE BASICS!
one or the other at first. cam or spark. spark is harder to **** up thus start there.
bump mid range to get the cylinder pressure up to make more off boost power then start playing around with big lumps eaither positive or negative at the transition point.
work it out from there, then go to cam.
yes, the higher the gear, the more engine load, the QUICKER the turbo will spool.
all other things being equal.
I understand what cam phasing does. I am simply saying I am seeing no results up to this point. I changed the cam timing in 1 degree changes. and didn't see any results. Trust me I have spent hundereds of dollars on dyno time trying to teach myself..... once I find that bal. I will be SHARING MY RESULTS!!!!! I am not here to keep anything from anyone. thats what a forum should be.
If you wish not to help then stop posting... your not helping any! I know how to tune and what does what. I am stating that cam phasing up to this point has not worked. thats why I am asking for any recom. I have paid my dues now I am looking for some ideas!
Originally Posted by marcusicp
Any plans to rev higher?
I will def. be pushing 7000-7500rpm. I think the meth will give me what I need for the fueling on the top end.
I didn't before because I was have some plug issues. that is now fixed.
more dyno testing coming soon!
Old Feb 16, 2009 | 07:17 PM
  #140
elecblue06's Avatar
umm he is trying to help.. why the hell do people get so butthurt and miss that
Old Feb 16, 2009 | 09:27 PM
  #141
06black's Avatar
you can probably draw my emotions from this. i never said i did or don't like him but i would never run anything from him on any car of mine, or a friends, or any one i know. i've seen his examples of tunes, and all that they lack. LSJ, LE5, ect.
any who, why would you mess with the intake cam first? or much at all?
the exhaust cam defines the fluid flow that determines how the turbo reacts.
your results clearly contradict your claims, it looks as if your understanding and your skills are average at best.
it not how much, but what direction, and at what ratio.
not my job to solve your poorly engineered system's flaws.
yet again, another point of direction for you.
slapping a different turbo on to a OE turbo car does not count as paying your dues, once again, average, and neither does averige results.
keep working, your a head of all those sheep whom only talk about turbo swaps.
Old Feb 16, 2009 | 10:24 PM
  #142
boostking's Avatar
when you refer to system do you mean the turbo kit?
I agree that I at this stage am average when it comes to tuning. an expert I'm not!
Old Feb 16, 2009 | 10:36 PM
  #143
06black's Avatar
system implys your entire....we'll.....system.
in this case. engine, manifolds, hardware, AND software.
read between the lines here, on cam settings.
system implies your entire....we'll.....system.
Old Feb 16, 2009 | 11:09 PM
  #144
DEJON-Dave's Avatar
I would also like to benefit from expert knowledge, but I can't "read between the lines". If you want to help, please just post your solution or give advice and some background as to your specific experience. Then we'd all appreciate it.
Old Feb 16, 2009 | 11:14 PM
  #145
Area47's Avatar
Rent me! per hour
playing with the cam phase can either increase, or decrease spool, and when set right it will increase power. hell a simple -3/-3 on it will pick up a smidge of power and decrease spool times.
there is also another apparent problem of running out of injector timing.
notice something between all the larger turbo lnf cars. they all seem to be around the same power levels, same boost. this right here. this is the answer to big numbers.
Old Feb 17, 2009 | 12:43 AM
  #146
SportredSS's Avatar
Not really
Originally Posted by WaRRioR-StaTuS
so u dont have a dp or exhaust right? So then after you get the dp and exhaust, after that you could be at 400whp 400wtq ..... what would be needed to see higher numbers after that? Also is this gonna benefit from the gm stage kit? Or should I get all the stuff and just tune it? I have alot of money saved and am SOOOOOO confused what I should buy
Realistic numbers for DP are about 5-7 whp and 3-4 whp for an exhaust upgrade....on the LNF that is....
Meth will do little for these LNF cars...If you have an intercooler upgrade and a few other things you're fine..... you dont want the air going into the engine to cold... and yes to cold is as bad as to hot......
I've seen several others with LNF try it and it's not worth the $400 to gain 5 whp..... Just like Hahn makes a claim of 15-17 whp for their cool ram, that's power a person should definately feel and yet several cool ram owners say it just sounds better, more cool but no real power increase... This is why the CAI experts (K&N) have not made a CAI for this car..... just like below 330 whp it's pointless to upgraded your exhaust on these cars......
Last edited by SportredSS; Feb 17, 2009 at 12:51 AM. Reason: Automerged Doublepost
Old Feb 17, 2009 | 12:54 AM
  #147
Area47's Avatar
Rent me! per hour
what makes you think meth injection is bad on these cars?
Old Feb 17, 2009 | 01:02 AM
  #148
berto's Avatar
Lets see some vids though
Old Feb 17, 2009 | 01:08 AM
  #149
elecblue06's Avatar
steve
Old Feb 17, 2009 | 06:58 AM
  #150
boostking's Avatar
let me better understand cam timing then. (maybe I'm not asking the right questions)
the more negative on the intake the more advanced it is right?
the more positive on the exhaust the more retarded right?
Thanks for posting Dave!
