pics of the carnage!
Old May 4, 2011 | 12:42 PM
JustACobalt's Avatar
well took the valve cover off to find this:
rockers are thrown all over the place, dropped a valve obviously...
10 o'clock to the spark plug hole on the right, the tip of the valve is broken off and the seat for the rocker snapped
heres a close up of the broken rocker seat and valve tip
all the rockers for the exhaust cam came off. what do you guys think? input would be helpful
Old May 4, 2011 | 01:14 PM
HHRSSouth's Avatar
Isn't this the same thing that happened to Badbaltguys old Hahn car that Chevycobaltss bought?
I could have swore Chevycobaltss said he found broken lash adjusters also while diagnosing what was wrong with the car.
Old May 4, 2011 | 01:15 PM
06G85's Avatar
There's your problem. Someone forgot to take the gauze out.
Old May 4, 2011 | 01:16 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Damnnn
Old May 4, 2011 | 01:19 PM
Phyrric's Avatar
Originally Posted by tylerjclance
Looks like long term that these LSJ's don't like turbo's too much :-/
Its an LNF haha
BYT*SS*TURBO's Avatar
Too bad it's an LNF lol..
Good thinking with the cotton on the spark plug holes, wouldn't want something to fall in the cylinders like metal chunks or a valve.. lol.
Old May 4, 2011 | 01:52 PM
seeyaass's Avatar
That's what it looked like when you took the valve cover off? Holy ****...
Old May 4, 2011 | 01:54 PM
08ssedan's Avatar
Old May 4, 2011 | 01:59 PM
iboost's Avatar
I broke a lash adjuster in my car. Just one though. I didn't even know it until I pulled the valve cover and swap it out...
Old May 4, 2011 | 02:00 PM
Chevycobaltss3's Avatar
Lol yeah i had three broke whwn i bought it from badbalt guy.....easy ass fix but still a waste of time lol
Old May 4, 2011 | 02:01 PM
Acey's Avatar
Oh ****.
Old May 4, 2011 | 02:14 PM
Gremlin85's Avatar
What'd you do?!?!?
Old May 4, 2011 | 02:22 PM
not cotton, disposable shop rags but thanks
so the only thing i really see that needs replacing is the rocker seat, weird as hell that it just snapped off. lash adjuster looks fine to me, just popped off. can anyone explain why all the rockers flew off? looks like im going to have to drop the engine after all. the guy before me tack welded the turbo to the downpipe AND the turbo to the manifold. what a dick...
so its going to be another week or so until i can find a shop to work because the driveway isnt going to cut it
Old May 4, 2011 | 02:25 PM
SSlobalt's Avatar
Did I read that right? Someone tack-welded the turbo? How do you tack weld cast-stainless and cast-iron together?
Old May 4, 2011 | 02:26 PM
Prestige_Worldwide's Avatar
Damn, that sucks.
Old May 4, 2011 | 02:27 PM
Very carefully
With a MIG, you would be amazed at what you can MAKE stick lol..
Old May 4, 2011 | 02:28 PM
no they tack welded the bolts to hold them instead of loc-tite or something. sorry should have clarified
SSlobalt's Avatar
Oh, I see. That was funny.
Old May 4, 2011 | 02:31 PM
Ure lash adjuster are broke or atleast that one... Lift the cams up by taking the cam guides out and take lash adjusters out and replace. Check each roller bearing on the rocker arm.
it was a good idea, but for the person taking it apart its a pita. plus its literally impossible to get to the bolts on the tubular manifold with the engine in the bay. im just going to drop the entire subframe and engine and pull the manifold off with the turbo and downpipe still attached lol
Old May 4, 2011 | 02:35 PM
SSlobalt's Avatar
So, the top of that one valve is broken off, right? Which piece of debris is the lash adjuster?
BartSS's Avatar
damn bro that sucks. What were the side effect you were having again?? i remember reading it somewhere but dont feel like searching
Old May 4, 2011 | 02:39 PM
My car sputtered uptop and was slow as **** lmao..... After i fixed the lash adjusters all was well.. I mean i coulnt rev the car more then 4k rpm somewut..... The broke peice in the head is the lash adjuster op.
cmiller8006's Avatar
That's not the problem. They don't like over reving that's all.
Old May 4, 2011 | 02:46 PM
SSlobalt's Avatar
So, the green arrow is the broken piece off the top of the valve and the red arrow is the lash adjuster? What is the blue arrow?
