pics of the carnage!
Old May 4, 2011 | 02:48 PM
Chevycobaltss3's Avatar
Thats also part of the lash adjuster..
Where is ure spring at lol and ure retainer
Nm i see it finnally loaded up
Last edited by Chevycobaltss3; May 4, 2011 at 02:48 PM. Reason: Automerged Doublepost
Old May 4, 2011 | 02:49 PM
SSlobalt's Avatar
Anyone got a blow-up of what the valve and rocker setup is supposed to look like? I crave the knowledge. Thanks.
Old May 4, 2011 | 02:50 PM
JustACobalt's Avatar
so #1 and #2 are the lash adjuster that broke. what is #3 though?
athere are some scratches on the rockers and cam lobes, will this be a problem? also will i be ok if i put a rocker in a different spot than it was though the wear pattern i different?
Old May 4, 2011 | 02:55 PM
Originally Posted by BartSS
damn bro that sucks. What were the side effect you were having again?? i remember reading it somewhere but dont feel like searching
i wasnt having any side effects at all, car was running great.
it all happened while doing a pull when i shifted from 3rd to 4th. my limiter is set up to 7k and possibly the lash adjuster broke and the valve dropped or i accidentally shifted from 3rd to 2nd. i really dont think its the latter one tho because im really careful about pulling the shifter straight back for that shift, i guess its possible tho...
Old May 4, 2011 | 03:00 PM
SSlobalt's Avatar
You would know if you money-shifted. There's no mistaking it.
Old May 4, 2011 | 03:02 PM
thats why i dont think i did that never even came to mind until seeing the damage. before now i thought the cylinder went lean
Old May 4, 2011 | 03:13 PM
Gremlin85's Avatar
How long have you been able to rev to 7k and how often do you do it?
I think it might have just let go after so long.... Just tired out and gave up.
I also asked because mine is set to 7k without upgraded springs or anything. I think I might be on borrowed time.
Old May 4, 2011 | 03:19 PM
honestly couldnt tell you. i bought the car and only put prob 4k miles on it and it has 30120 as of now. i myself probably took it up to 7k 20 times total in the 4k miles i had it. i usually shifted around 6700 just to be safe. there were signs that the car was beat on before me though and i know the rev limiter was set above 7k when i bought it because ive gone to 7200 once before i got it retuned
Old May 4, 2011 | 03:21 PM
mkriebs's Avatar
What springs are you running? I think part of the problem are weak, or out of spec springs. We have only popped ONE on our shop cars, and that was on stock springs. My guess is something else broke before your lash adjuster came off. Typically they just pop off and not shatter like that. I'm guessing valve float and something met not so nicely in there.
Old May 4, 2011 | 03:27 PM
iboost's Avatar
I think that #3 is part of whats inside the lash adjuster. I think I remember seeing that in there...
  #36
i dont know exactly because i bought the car already modded...
theres zzp springs with the blue painted on one side. mine have green painted.
Old May 4, 2011 | 03:34 PM
  #37
Gremlin85's Avatar
Sounds like the PO hit that 7k redline more often than not.
Mine has 36,500 and a good 15,000 has been tuned to a 7k redline.... yeeeeeaaahhh, it's time to upgrade my springs....
Old May 4, 2011 | 04:25 PM
  #38
cmiller8006's Avatar
The stock springs have a green strip on them. I think those are stockers in there still.
Old May 4, 2011 | 04:27 PM
  #39
I had a rev limit of 7000 rpms and when I took the motor apart there was signs of over reving on the roller followers and lash adjusters, I ended up replacing all of mine.
Old May 4, 2011 | 04:41 PM
  #40
yeah i think im getting the zzp 78 pounders. is it worth it to also get the retainers? i think im going to stay around 400 whp and 7k redline for a while
Old May 4, 2011 | 04:44 PM
  #41
Get the new retainers as well.....
Old May 4, 2011 | 05:17 PM
  #42
alright. can anyone confirm that all three broken piece are the lash adjuster?
what do you guys think about reusing the rockers even if they might not be placed in the existing spot?
Old May 4, 2011 | 05:29 PM
  #43
Yes they are all three the lash adjuster. Just look to se if ure rocker arm has damage if s replace it.
Old May 4, 2011 | 05:47 PM
  #44
Gremlin85's Avatar
What signs?
I'm gonna pull my valve cover this weekend when I do my oil change out of sheer paranoia...
Old May 4, 2011 | 06:20 PM
  #45
Gremlin85's Avatar
And here is the theory...
Lasher broke, spring and rocker let go. All this looks like it's on cylinder #4. Once the rocker and spring flew out, they caused a chain reaction, hitting the next rocker in line knocking that loose and so on. That's why all of them are laying around like that.
And since that valve dropped, I'd be replacing it as well as it's most likely bent. As a matter of fact... it might be time to just upgrade everything.
Old May 4, 2011 | 07:39 PM
  #46
Mike_peperni's Avatar
You probably shifted from 3rd to 2nd, im 100% sure since that is what happened to me 1.5 weeks ago...
lol
i got a phone while going WOT in 3rd , then shifted into 2nd instead of 4th...
I never missed a single shift and i felt pretty stupid after that...
I have 1 broken lash adjuster, 3 rockers were off, but only one lash broken, i ordered all 16 lash adjusters and bought 3 rockers, they look not too bad but i dont want to take any risk.
So id say if you blew all of them out you were clearly over reving it, it felt really smooth getting into 2nd gear... it was almost easier than it is normaly... lol i quickly pushed on the clutch as soon as i felt the car slowing down, the rpm was at 7500 and going down when i looked at it, but id say it got up to 8500-9000 at 100mph in 2nd gear?
I also have some wear mark on the rocker, but i cannot feel anything with finger nail. and one tiny scratch, barely visible, but i can feel it slightly with the finger nail, on the cam lobe where the lash broke...
As soon as you cant feel anything with a finger nail you should be alright, from what ive been told.
By the way thx for all of those that helped me with my issue (ChevycobaltSS3, Cmiller and Matt @ ZZP)
Still waiting for the parts, should get here by the end of the week....
My car sounded like a subaru and had less power...
Thats how the worst rocker look like:
and thats where one of the rocker was sitting...
Sorry that you had more damage, took me a while to remove the valve cover, wanted to do it myself and not go to the dealer for that.
Old May 4, 2011 | 07:50 PM
  #47
Like always bro u r welcome
Old May 4, 2011 | 09:04 PM
  #48
wow lots of good information here.
so i also have scratches on the cam, going to check if they can be sanded off. replacing 8 rockers that all are scratched, a valve, retainer and spring. might not go with the 78# ill have to see what the funds are.
Old May 4, 2011 | 09:06 PM
  #49
Gremlin85's Avatar
Don't be revving to 7+k without those springs... I'm gonna be taking my own advice.
Old May 4, 2011 | 09:07 PM
  #50
Doubt u need a valve id put a new spring and retainer on along with rocker and lash adjuster and check comression unless ure valve is broke.. Id do this first
