pics of the carnage!
Old May 5, 2011 | 06:02 PM
  #76
JustACobalt's Avatar
Originally Posted by newt
Ouch, thats rough.
This happened to me once, it only broke one of the lash adjusters on the exhaust side and kicked out the rocker...made my car sound like a Subaru...pretty cool. I was lucky tho and it didn't scare the cam lobes.
Considering yours did score the cam lobes, I would HIGHLY suguest getting new cams. Trying to sand them will not work well and if you leave the scratches it will end up chewing the hell out the roller on your rocker.
From the pics your cam lobes seem to be pretty beaten up, I can swear I can see what looks to be flat spots or wear marks.
This was almost definitely caused by Valve Float IMHO.
I've had this theory for a while.....since the only thing holding the rocker in place is the tension applied to it via the valve spring, when your valves float the rocker looses contact with the cam and then evenutally causes the cam to come back and "smack" into the rocker, shearing off the tip of the lash adjuster. Once that happens you get a nice mess under your valve cover like in those photos.
That much boost, on that size turbo and 7000rpm I would be fairly certain this was cause by a pretty serious case of valve float.
Upgraded valve springs should definitely be on your list of when you rebuild that motor so this won't happen again.
I'm not sure why I'm even helping you out since some of your "tough guy" comments in the ZZP LSJ thread....but I've never been one to hold much of a grudge and always try to help a fellow enthusiast.
you ARE holding a grudge since you are mentioning it now over a month later... and i think you got everyone a little fired up in that thread with your comments. but anyways im pretty low on funds for this so im prob going the cheap route. ill be getting 8 new lash adjusters, 8 new rocker arms, and 1 valve so far. a friend of a friend is going to look at the cam tmrw and decide whether its reusable or repairable. already looking at prob 400 in parts and i havent even looked at the piston...
Old May 5, 2011 | 06:45 PM
  #77
newt's Avatar
Nope, I'm good. Its the internet after all, I always seem to get into arguments for some reason...lol. Just figured I'd mention it since it was kinda funny.
Either way, hopefully you get it fixed up. Good luck!
Old May 5, 2011 | 09:32 PM
  #78
Mike_peperni's Avatar
Good luck with your repair!
I got my parts tonight! going to repair saturday morning, hopefully everything will go smooth and well, i hope.
Old May 6, 2011 | 03:14 AM
  #79
thanks man hopefully she'll be back on the road soon
appreciate it, its a long road ahead but ill make sure it gets done. hope everything goes well for you, was it a rocker arm and lash adjuster?
Old May 6, 2011 | 06:04 AM
  #80
I got 3 rockers, and 16 lash adjusters. Even if the other 13s were probably fine, just did not wanted to take any risk.
Old May 11, 2011 | 07:37 PM
  #81
i was talking to a guy and he said there is a good chance the connecting rod is bent since a valve was dropped. what do you guys think?
Old May 11, 2011 | 07:56 PM
  #82
wutsthisim12's Avatar
um i think a forged rod can hold up to an interfering valve. piston may be toast though. the valves probably just mangled.
Old May 11, 2011 | 09:16 PM
  #83
Chevycobaltss3's Avatar
^Truth..
Old May 11, 2011 | 10:40 PM
  #84
Zero6LS's Avatar
Damn that sux!! Reason number one I'm never buying a car that someone else modified. **** brakes an no one can figure why lol
Old May 12, 2011 | 07:38 AM
  #85
lnf has forged rods?
Old May 12, 2011 | 08:05 AM
  #86
Yes.....
Old May 12, 2011 | 08:18 AM
  #87
06SS ALL DAY's Avatar
Originally Posted by 06G85
There's your problem. Someone forgot to take the gauze out.
nice sig. where'd ya get the pic on the left from?????? lollll
Old May 12, 2011 | 09:21 AM
  #88
Originally Posted by Chevycobaltss3
Yes.....
alright whats the risk you think just reusing the stock rods? ill be doing business with you shortly btw maybe today
Old May 12, 2011 | 09:36 AM
  #89
K i do highly doubt you have damage to your piston as well.. If you do you will see it.
No risk with useing the rods btw... Check the bearings
Last edited by Chevycobaltss3; May 12, 2011 at 09:36 AM. Reason: Automerged Doublepost
Old May 12, 2011 | 09:40 AM
  #90
yep prob dropping the engine a few inches down today and pulling off the manifold and head. guess we will just have to see, pics as well. do you recommend checking bearing clearances with a plastigauge?
Old May 12, 2011 | 09:54 AM
  #91
BlueStang's Avatar
A little duct tape & crazy clue and your good to go
Old May 12, 2011 | 10:14 AM
  #92
Yeah check gapage if you can.....
Old May 12, 2011 | 11:25 AM
  #93
cubaniche's Avatar
Hey OP, did you decide on which springs your gonna use? As I stated earlier I bought the supertech 78lb kit and installed them over the weekend. I checked them out and rotated the crank and they seemed to be moving well with no contact on the sidewalls of the head but someone told me on another forum that I should have machined the head to make more room on the sides of the springs. I never heard of ppl doing that for the supertechs, but just thougt Id mentionit since your about to do the same
Old May 12, 2011 | 11:26 AM
  #94
i had supertechs on my lsj, i didnt do that, but on the lnf i would say its not a must.....
Old May 12, 2011 | 11:34 AM
  #95
cubaniche's Avatar
Well they are basically the same head makeup up top except for the cams and HPFP area on the intake cam side. I figure if for some reason they do contact its got to be miniscule as I couldnt see it with my eyes and a large flourescent lamp illuminating the area, and would probably shave off in the first minute of having the engine running.
Anyways, sorry to post my own question in your thread OP
But thanks for answering my question chevycobaltss3
Old May 12, 2011 | 11:38 AM
  #96
Sorry if i came of as a smart ass i wasnt meanign to but........ When i installed my valves, retainers and ect, they were close but they never touched, even with my rev of 8k and some.........
Old May 12, 2011 | 11:44 AM
  #97
cubaniche's Avatar
No man, not at all! lol Its exactly what I wanted to know, as I hadnt heard of anyone having to make room for the springs before. Its not like they are 98 pounders lol
Thanks again and good luck with getting the OP back up and running
Old May 12, 2011 | 11:46 AM
  #98
Lol yeah, i blew a big nice hole on my HAHN ic endtank so ill be welding that back up soon, so till then im boosting 1lbs hahahaha
Old May 12, 2011 | 11:49 AM
  #99
cubaniche's Avatar
Ouch! Damn I keep hearing about this happening on HAHN ICs sometimes. Im about to be strapping on the BNR 2871 and probably be at about 26psi, i hope Im not one of the ones that this happens to too lol
Good luck on the welding and fix bro! I go into boost withdrawls without my car lol
Old May 12, 2011 | 11:52 AM
  #100
lmao, yeah i do to.. I mean im basically a na right now lol..... i was only boosting 22 with a spike of 24 and it blew, i have pushed 35ish before without issue but damn!!!
