Plugs
I wouldn't recommend those. I used them in my old car and they didn't even last 2 weeks before they started making the motor misfire like crazy. I did make sure the gap was correct before they were installed.
Stock plugs are top of the line NGK iridium plugs, but they do say AC Delco I believe. You could go one heat range colder if you are tuned kinda lean and running a ton of timing but you might run into fouling issues if you start and stop your car a lot. The 07 Solstice and SKY had that issue because of colder plugs and different cam angle settings.
agentirons
Oct 16, 2015 02:11 AM
