Plugs
Old May 4, 2009 | 09:49 PM
Mike09SS's Avatar
Plugs
What plugs do you guys recommend for replacement of the stock ones? Also spacing? any info is appreciated. Thanks
Old May 5, 2009 | 12:11 AM
NarutoDF's Avatar
well when i ordered my hahn intake it came with a recomendation in the install sheet of upgrading the plugs to autolight XP's
Old May 5, 2009 | 12:20 AM
09SS's Avatar
I wouldn't recommend those. I used them in my old car and they didn't even last 2 weeks before they started making the motor misfire like crazy. I did make sure the gap was correct before they were installed.
Old May 5, 2009 | 09:00 AM
Terminator2's Avatar
Stock plugs are top of the line NGK iridium plugs, but they do say AC Delco I believe. You could go one heat range colder if you are tuned kinda lean and running a ton of timing but you might run into fouling issues if you start and stop your car a lot. The 07 Solstice and SKY had that issue because of colder plugs and different cam angle settings.
Old May 5, 2009 | 01:02 PM
gatekeeper's Avatar
I'd stick with what it came with from factory, especially if we've got NGK Iridiums (I haven't pulled mine to see). Maybe squeeze the gap down a little if you get blowout.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
