porus block
Old Feb 25, 2011 | 08:00 PM
  #51
army_greywolf's Avatar
most notice problems at or before 20k miles, almost in every case it is noticed before the powertrain warranty is up.
Old Feb 25, 2011 | 08:15 PM
  #52
ronn's Avatar
You would think it would show up rather early most of the time...it's a fundamental defect with little *wear and tear* factor.
"in every case it is noticed before the powertrain warranty is up"
..I would hope so..100K miles/5yrs!
Old Feb 25, 2011 | 08:26 PM
  #53
so many factors in casting you cant accurately predict how long a block will last even though it dye tested fine.
Old Feb 25, 2011 | 09:15 PM
  #54
Erod's Avatar
Moderator Alumni
Act like an adult, or else, all of you.
Old Feb 25, 2011 | 10:21 PM
  #55
superrslow's Avatar
yes
Old Feb 25, 2011 | 10:50 PM
  #56
denlou's Avatar
Originally Posted by superrslow
yes
no you shut up
Old Mar 4, 2011 | 02:29 PM
  #57
vahdyx's Avatar
Out of curiosity, if I did have this issue, would I buy this to fix that?
Cobalt & Ion ---> ZZ Performance
Old Mar 4, 2011 | 02:43 PM
  #58
sponge14's Avatar
I believe it's the block and not the heads.
Old Mar 4, 2011 | 02:48 PM
  #59
SSlobalt's Avatar
Werd. Block is cast in styrofoam.
Old Mar 4, 2011 | 03:15 PM
  #60
vahdyx's Avatar
How would you strengthen the block?
Old Mar 4, 2011 | 03:38 PM
  #61
StreetDrag03's Avatar
Originally Posted by ronn
Intersting info..
Does this usually appear within the first 5K miles or so? By that I mean...
if someone (ie, me) has gone 20K mi without a problem are they *out of the woods* with this, or can the problem surface at any time?
From my experience, no. Mine gave up at 24,500ish.
Old Mar 4, 2011 | 04:00 PM
  #62
SSlobalt's Avatar
You can't. It is what it is.
Old Mar 4, 2011 | 05:18 PM
  #63
ronn's Avatar
Were there any indications prior....like losing coolant much earlier?
Old Mar 4, 2011 | 06:03 PM
  #64
Not at all, just got "low coolant" on the DIC one day. Took it to the dealership after almost 700 miles (I was out of the state on a quick day trip), they compression tested it along with many other tests and found nothing, so they put some dye in it and sent me on my way. About 150 miles later, "low coolant" again, and thats when I got my new motor. It even ran fine all the way til the end.
Old Mar 5, 2011 | 12:07 AM
  #65
Erod's Avatar
Moderator Alumni
hi, my usual comment, next insulting comment in this thread gets a vacation.
xoxoxoxox
Old Mar 5, 2011 | 01:44 AM
  #66
Erick161's Avatar
I have an LSJ. Ive topped off my coolant like 6-7 times in a year. I know this mostly affects LNFs, but any LSJs have this problem? Any other possibilities? Head gasket? Water Pump?
Old Mar 5, 2011 | 02:36 AM
  #67
vahdyx's Avatar
Does the LNF have the same block as LSJ
Old Mar 5, 2011 | 01:14 PM
  #68
vahdyx's Avatar
Seriously there's nothing we can do? Sleeving anything? That sucks, maybe ZZP will make a solution if we ask?
Old Mar 5, 2011 | 02:04 PM
  #69
sponge14's Avatar
No, it's a defect when they poured the casting. It's not just in the cylinder's, coolant passages, etc.
Old Mar 5, 2011 | 03:21 PM
  #70
SSlobalt's Avatar
There just can't be any easy solution. It's like the '06-'08 R18 Civic engine blocks that are cracking at 60K miles. Honda just replaces them as they crack. There's no way to strengthen the block to remedy the casting issue.
Old Mar 5, 2011 | 03:57 PM
  #71
Nighthawk243's Avatar
idk how to spell but im pretty sure i have one
left for a gunshow today on the way home seen the low coolant light and to my suprise to coolant and a gurgling sound from the back of the motor.
i live about 20 miles from any place that sells coolant so filled it with water. ran it and no overheating no leaking.
although im not smoking anything. the oil looks fine.
andddddd no warranty anymore =[ wow motors are like 5 grand
this should be a recall though. there have been a number of leaky blocks hell i have a buddy with an 09 as well that had one.
If you're a 2009, you should still have the powertrain warranty unless you somehow racked up over 100,000 miles on an 09.
Old Mar 5, 2011 | 04:13 PM
  #72
vahdyx's Avatar
Well I don't even have 10k miles yet and I'm a 2009, but if something like this happens, man that'll suck to have to remove everything on my car and take it in. Better than buying a motor I guess.
Old Apr 20, 2011 | 11:35 PM
  #73
MaGNuM16's Avatar
i have a good feeling i got a prorous block too. i bought my car used from a chevy dealership , got extra warranty to. When i first got it i notice in the engine bay they noted "coolant dye added" i asked my dad he said it could of had a leak so they added dye to trace it with a black light . but since ive had the car , ive had the "lowcoolant" probably come up 3-4 times a year. Bringing the car in sat for a po446 fix might as well tell them to check for this too?
Old Apr 21, 2011 | 01:01 AM
  #74
DARIN616's Avatar
low coolant on my DIC recently....... uhg
Old Apr 21, 2011 | 01:24 AM
  #75
AndrewSS/TC's Avatar
I can't tell if my block is porous cause my radiator leaks LOL
