Pre-Tune Checklist
Old Mar 5, 2012 | 06:55 PM
Kbbalt's Avatar
Pre-Tune Checklist
Well i plan on driving to PA on Sat to get tuned by BYT.
I just wanted to do a couple of preliminary things before hand, thought i'd run it pass the net First
1. Change the 4 clamps on the charge piping to intercooler connections, they are T-clamps they are the regular ol Screw clamps. T-clamps are everywhere else.
2. install the Treadstone Air Straightener in the Devil Dejon SRI.
3. uninstall the Defouler on the Bad mab Dp
4. and here the problem, Change the spark plugs. I wanted to get stock A/c Delcos but no auto store carries them around here. I just see autolites are they any good? Or should i just special order the the Ac and install them when the get here?
I taking off thursday to handle this and driving up Sat.
Thanks in Advance.
Old Mar 5, 2012 | 07:02 PM
05Slowline's Avatar
41-108 I think is the stock part # just get them off amazon.
Old Mar 5, 2012 | 07:07 PM
09BlueBaltSS's Avatar
Or a dealer or CED. Order now to have by friday
Old Mar 5, 2012 | 07:09 PM
Kbbalt's Avatar
Anything Else? You think i could Run 25 PSI?
yea i think im going to just order the A/C delcos and hope they get here before Sat.
Old Mar 5, 2012 | 07:14 PM
24 is about the max for the k04. You dont make any more hp after that(just torque) and the air charge starts to get way too hot.
Old Mar 5, 2012 | 07:31 PM
Kbbalt's Avatar
I figured since i had the intercooler and Charge piping i could get away with it. Alright.
Old Mar 5, 2012 | 07:43 PM
chitala383's Avatar
Let me know how it goes with the air straightener. I talked to nick today and he said he doesn't really recommend them. From his past experiences he said they seem to restrict air flow a bit. But good luck and enjoy your BYT tune. I love mine :-)
Old Mar 5, 2012 | 07:45 PM
Kbbalt's Avatar
Really? I hope not? The Dejon Skews the trims so much aint cant be that bad. I'll post it the review afterwards
Old Mar 5, 2012 | 08:31 PM
AARON-SS-TC's Avatar
Stock ac delcos are the only way to go with the stock .035 gap...hope you have an aftermarket clutch and aftermarket intercooler. You will need the intercooler to raise the timing in the midrange to gain more power, and you need a new clutch because the torque will blow the hell outta the stock one...
Old Mar 5, 2012 | 08:51 PM
Kbbalt's Avatar
Thanks AAron i have EVERY bolt ont except cat back....
The clutch is being ordered from Ky Either before the end of the month or in MAY, I have a friend who can do it in a day we did it on my cavalier twice... So im not to worried about blowing it up. I really want new tires before the clutch...im riding on winters.(came with the car)
Its good to have a very good mechanic friend... he pretty taught me everything i know and helps a ton... he is doing my friends Supra Build i'll post it up if you guys wanna see
Old Mar 5, 2012 | 08:59 PM
Chevycobaltss3's Avatar
Nick obviously did it wrong if he said it restricts flow. You don't put the straightner.right in fromt of the sensor. You put it a inch + away to straighten air out. Think of it like a wind stream bouncing off wall to wall and once it has somthing to sraighten it out it can be read easier.
Old Mar 5, 2012 | 09:10 PM
Good luck man, and hopefully everything stays in tact after the tune. My flippin car was perfect till the tune, then fell apart soon after...lol
Old Mar 5, 2012 | 09:21 PM
chitala383's Avatar
I'm going back to see him on the 17th. I'm gonna put the air straightener in and have him tweak my tune with it. I last ran 327 whp, so if it's significantly less than that after getting tweaked then I'll make my decision.
HyperMuffin
Forced Induction
12
Jun 3, 2010 12:30 PM
HyperMuffin
May 28, 2010 11:43 AM
popeye55
Mar 2, 2009 02:11 PM
MadBrad
Mar 7, 2008 10:08 AM
