Problems
Old Mar 28, 2012 | 01:47 PM
  #76
AARON-SS-TC's Avatar
im def. #5...lol
#4 is done, and so is #3.
i will check #2 and #1 will be replaced soon with a forged.
Old Apr 22, 2012 | 08:42 AM
  #77
soooo, my car has been doing the dododo, gobble gobble gobble thing from the turbo for a bit now. lol. Yesterday i went to accelerate on the highway and the car wouldnt!!! it would boost up to 10psi, then fall on its face. Tried one more time and the same outcome....Still no check engine light even after driving home, and drove fine while i was slow driving(not boosting)...
Old Apr 30, 2012 | 09:33 AM
  #78
Speed_Thrills's Avatar
What ever came of the boost leak test?
Old Apr 30, 2012 | 12:26 PM
  #79
i never did the actual test..trouble shooted, and i really thought it was the bpv, so it is being ordered along with a new zzp low profile intercooler. i will have it all on and retuned in 2 weeks and hopefully the only problem i will have left is installing the stage 3 ky clutch i have.
Old Apr 30, 2012 | 03:12 PM
  #80
Pepsi's Avatar
try doing a compression test. it only takes a few minutes to pull the spark plugs
Old Apr 30, 2012 | 05:24 PM
  #81
Knightwolf's Avatar
Pepsi? Where have I seen that name before? Lol.. warcraft 3 maybe? No, not the drink either lol.. not trying to be sarcastic :P Just wondering if you're the same guy I knew way back when from a blizzard rts of some sort.
Old May 1, 2012 | 04:42 PM
  #82
so, i go to work this morning and i get the "flutter", bogging down syndrome again, only this time the car flashes a cel!!! so i get it scanned and its a misfire code p0303.
My plugs were brand new just before the tune, and the coils looked great as well. I am gonna check them and see if its them, if not, then im in trouble
my car has 42k babied miles, i cant believe this.
update: so i removed the spark plug in cylinder 3 and it was completely black and chared worse than the old plugs that i took out with 40k miles on it..i ran it with the new plug and didnt get the bogging, but it was always random anyways, so i still dont know if its fixed.
Old May 2, 2012 | 09:01 AM
  #83
ive had a few of you pm me saying it may just be a boost leak and its causing a misfire...hopefully you are correct because ive had a few say it may be the lash adjusters, and im hoping not...i never over rev my engine, nor do i beat on it, so i really hope its not the lash adjusters
Old May 11, 2012 | 01:23 PM
  #84
p0451 and (p0303 again today). i have already a few months ago replaced my purge solinoid, but maybe it needs it again, but would it make a misfire too?
Old May 11, 2012 | 05:10 PM
  #85
sstupid's Avatar
I'm beginning to wonder if you have that carbon buildup issue on the valve seats. Maybe you should do a compression and leakdown test.
Old May 12, 2012 | 02:16 AM
  #86
damn, i dont know...will do asap
Old May 12, 2012 | 03:19 AM
  #87
FasterIsBetter's Avatar
Yeah, boost leak test, check your wastegate rod, compression test, cylinder leak down test in that order.
Old May 12, 2012 | 03:53 AM
  #88
Zander916's Avatar
Something you could do real quick is just remove the BPV and check it for tears. The only cost is a few minutes of your time. Even though you plan to replace it anyway if you did find a tear at least you would have peace of mind for discovering something causing your issue.
I had a coil go out once. It was early on........ I think 30-40K miles. It made the car run like ass and took a while to throw a code. Another easy, and free test... swap #3 coil with another one and see if your misfire follows it. I also had an exhaust cam solenoid go bad but that caused random misfires on all cyl. So I don't think that would be the case here.
That's at least two free, easy, useful tests you can do.
I would definitely do a compression test. I have a mild tune running 21-22 PSI and I broke TWO pistons! My test at the time came back as 136 - 126 - 142 - 30
Now... after a long while and a 20 overbore to correct scratches I'm 165-170 on all. I hate to cause you a bunch of worry, but it is a reality we face with these LNF's.
Old May 12, 2012 | 11:58 AM
  #89
thanks zander for your reply..i appreciate it.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
