Problems with BOV and Cel mode
Old Jan 12, 2009 | 04:22 PM
PimpLay2's Avatar
Originally Posted by 08BlackSS/TC
has absolutely nothing to do with the tune
x'a million
Originally Posted by kling1022
sweet pimp. Perfect vid. He should be able to get it from that
thanks
Originally Posted by Hotshot768
thanks for the video. I will test it when I get home. I will also do a video on how each setup affects my car. the video may be long but it will show. I think my ppc tuner may have made the difference too but I highly doubt it.
no problem man
Old Jan 13, 2009 | 12:41 AM
Hotshot768's Avatar
Ok. so I tried the method by pimplay. You can tell it tries to blow off but it sounds more like the turboxs bloww off than the Greddy type S and its a weak blow off. it on wants to blow off past 15 pounds of boost. I have a video of it and the other methods than ive tried but they its too big of a video to upload to photobucket so tomorrow when I get out of school I will have 3 videos to show each method and how it affects my car. I do appreciate the help from everyone. Hopefully we can figure out why its not blowing off like its suppose to or what method make it work right without throw codes or CEL mode.
Old Jan 13, 2009 | 01:53 AM
HB_SS/TC's Avatar
That's EXACTLY how I said he should have it.
PimpLay2,
Now if I were to get a block off plate how would it look?
Old Jan 13, 2009 | 02:20 AM
PimpLay2's Avatar
dude if it wants to blow off at high boost then there must be a washer on the piston weighing it down.... thats the only thing i can think of
Originally Posted by HB_SS/TC
PimpLay2,
the same just use the hose that was on the bypass.... hook that to your bov and run the other end to the black vacuum box or w.e the call that damn thing lol
Old Jan 18, 2009 | 12:49 AM
sporttintturbo's Avatar
good advice guy great video pimplay now im not confused as all looks simple as ****. my bov should be here in a few days already got dejon charge piping
Old Jan 18, 2009 | 01:06 AM
kling1022's Avatar
i got mine done today. The only problem is I am getting boost shutter aka compressor surge. Need to fix it somehow. Any suggestions?
Old Jan 18, 2009 | 09:26 AM
peachpuff's Avatar
Are you sure you're not mixing up bov flutter with compressor surge? Compressor surge happens when the turbo spools too quickly, not when you let off and let the bov vent.
Old Jan 18, 2009 | 12:17 PM
kling1022's Avatar
well it only happens during low boost. When I boost moderatly or full boost it doesn't shutter. I have heard from some people that it is normal with the HKS to do this at low boost
Old Jan 18, 2009 | 01:47 PM
peachpuff's Avatar
The hks has two valves to vent air, one for low boost and one for high boost. You're probably hearing the low boost valve opening, and yes it flutters like that, the high boost one just lets out a loud squeal.
Old Jan 18, 2009 | 02:30 PM
kling1022's Avatar
oh ok thanks dude. You're very knowledgable
Old Jan 18, 2009 | 05:01 PM
  #36
i cannot wait to get my blow off. im staring at my ******* charge pipes haha ima drive to IL and steal your ssqv so i can stick mine on j/k haha
Old Jan 18, 2009 | 06:06 PM
  #37
kling1022's Avatar
haha come on down. We'll have a fun ol' time. The street are clear here and it's like 50 degrees
Old Jan 21, 2009 | 07:58 AM
  #38
that just made my ******* make a sour face lol. its 20 degrees here and snowing like ***** and i just put my piping on. blow off should be here friday lol. cannnot wait! there is a mazadaspeed three here that got a bov and blows off everywhere haha wait till i see that **********!
Old Jan 21, 2009 | 11:11 AM
  #39
M1kl0's Avatar
nice vid pimplay. now we all know. i either wanna run a greddy rs bov or hks ssqv. only problem is, do i put the greddy on my 240 or my balt first? i still gotta save for the hks ssqv. hmmmm...
Old Jan 21, 2009 | 11:31 AM
  #40
BartSS's Avatar
Pimplay when i talked to Dave at Dejon he told me to t off the line on top of that sensor not the one in the left. Will this make any difference??
Old Jan 21, 2009 | 11:47 AM
  #41
roadrage06's Avatar
sounds like you need someone who can tune the LNF. why would you want to change the piping to trick the engine? It won't run at full potential. You need to run the piping the proper way and tune it to run the way you want it to.
Old Mar 9, 2009 | 01:04 PM
  #42
BoostedSSCobalt's Avatar
Add delete plate, then run the vacuum line from the stock BPV to your new BOV. Right?
Old Mar 10, 2009 | 05:37 AM
  #43
i got the type s now too i had to mess with the springs inside to get it to work properly.
Old Mar 10, 2009 | 05:56 AM
  #44
hiltu's Avatar
Yes, if it seems like your stock bypass valve is still "lifting", something that might happen if boost is increased, than you may wanna throw down $13 to get dejons bpv spring upgrade, its as easy to install as it is easy on the wallet. You'll need another line to go to the bov too, i have synapse engineering's bov and it has three ports, so i used the stock line u mentioned and also a boost only source which can be gained from the waste gate actuator by the boost solenoid or the vacuum line leaving you T-MAP sensor on the cold side intercooler piping
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
