Ran my Balt on a Dynojet Today
Old May 16, 2010 | 01:53 PM
Rissa's Avatar
I like.
Old May 16, 2010 | 01:54 PM
HHRSSouth's Avatar
Old May 16, 2010 | 02:20 PM
SeanEE89's Avatar
damn!
Old May 16, 2010 | 02:22 PM
mkriebs's Avatar
Good job Matt!! You have a very respectable car.
Old May 16, 2010 | 02:38 PM
Boosted_Cobalt09's Avatar
congrats!
Old May 16, 2010 | 03:42 PM
Originally Posted by Matt M
It makes almost exactly the same peak hp on 93. In fact, the highest hp I've made on our dyno with this setup was on 93.(482whp) DI motors aren't like what you are used to. The advantages to running higher octane and added timing are:
1. The power doesn't fall off until a higher RPM.
2. Less chance of damaging a piston.
ah gotya, thank you for clarification, again nice work
Old May 16, 2010 | 04:09 PM
blrt's Avatar
Nice work Matt/ZZP.. Keep up the R&D and them new parts coming..
Old May 16, 2010 | 04:56 PM
tomj77's Avatar
Originally Posted by PrincessTurbo
ha , 33 mpg 500 WHP , thats funny , what is it while in boost
probably 33 gallons to the mile. lol
Old May 16, 2010 | 05:17 PM
selfinfliction's Avatar
not too shabby, top fuel dragsters use approx. 60 gallons per mile of nitromethane lol
Old May 16, 2010 | 06:12 PM
redstarpa69's Avatar
Matt,
have you dyno'd the kit using 110 or higher? and what rpm range does the pwr fall off?
since the 3bar comes with the kit, but what about the ECM?? send in mine or I get one programmed (swap)??
i bet, i can get this motor to break the 10 or 9 sec range in a sedan and 8 sec range in a coupe..
the more i read about the improvements on this, the more i think this motor can take it.. (550/600+whp range w/bullet proof bottom & top)
ive cleaned up my pm box.. my bad.
Old May 16, 2010 | 06:27 PM
  #36
beast10007's Avatar
my uncles nitro bike that went 250mph at 5.85 in the 1/4miles goes through 5.25gal a pass
Old May 17, 2010 | 07:24 AM
  #37
Sweetsandman's Avatar
It has selectable boost level, raised fuel pressure, modified fan settings, cat warm-up delete, duty cycles set up for the TiAL wastegate, and more. We put our tune on this file, and it can be adjusted by anyone with HP tuners.
God Damnit...I wish HPT would unlock that
Old May 17, 2010 | 02:41 PM
  #38
EthensCobalt's Avatar
when you taking the car to the track with a video camera
Old May 17, 2010 | 02:56 PM
  #39
Supercharged Guy's Avatar
He's already brought the car to the track and posted a vid on youtube
He ran a 11.4 at 126
With the Bullseye 252et and everything else
Old May 17, 2010 | 06:04 PM
  #40
MaxVQ35DE's Avatar
i need a saturn sky and This kit
Old May 17, 2010 | 09:33 PM
  #41
Matt M's Avatar
Actually that was with the S256 and ported head last year. It would have been much quicker, but we had a lot of ECM issues. We raced once this year and ran 11.8 at 127 launching conservatively. When we turned it up and launched with boost, the trans grenaded. We will have it back at the track within the next couple weeks.
Old May 18, 2010 | 06:28 AM
  #42
mkriebs's Avatar
1 mph faster trap, and .4 seconds slower.
I forsee some good times in the future!!!
Old May 18, 2010 | 06:46 AM
  #43
Maxim_X's Avatar
With that kind of power you should see 130 plus. That turbo is clearly a great choice for these cars.
Old May 18, 2010 | 03:27 PM
  #44
a case of someone opening their mouth when they dont need to be...........
Old May 19, 2010 | 03:18 PM
  #45
Dezod's Avatar
We headed out to the Bullseye Power open house today. My SS/T is set up with the following:
ZZP turbo upgrade kit with Bullseye S252et turbo
ZZP upper charge tube with 50mm BOV
ZZP Intercooler (standard, not the race IC)
ZZP lower charge tube with MAF relocation
ZZP dyno tune on ZZP/Trifecta ECM
ZZP Valvesprings
ZZP S4+ clutch
ZZP transmission
ZZP catback
104 octane
Stock cylinder head
Stock cams
Every mod on this car is available to purchase through us.
28psi fading to 25 by 6800 RPM. I dyno'd this etup earlier in the day at our shop and put down 465whp STD.
First pull on the dynojet read 497sae whp and 509 tq.(514/526 std) The graph was pretty choppy, but I did another pull.(It was two pulls for $55 at the open house.) The 2nd pull graph was much smoother and I put down 508 STD whp and 494 STD ft lbs.
Despite having a 4.45 final drive in the ZZP trans, I still averaged 33mpg on the way home crusing 80mph most of the time.
Nice power!
06MetallicBalt
Jul 20, 2025 08:47 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
