Random Codes 0099 0098 0238
Old Jul 14, 2014 | 09:46 AM
d.j.wagner1991's Avatar
Any help you guys can offer would be great
Car is stock.
two weeks ago I was driving and the car stumbled as I went through the gears and kinda died so I pulled off the road and restarted it. Got the following codes: 0099 0098 0238. It ran without boost but I got where I was going. I pulled the intake air sensor, plugged it back in and it ran fine no problems
Two days ago the same stumbling happened and the codes popped up again. Both times it happened I was moving up through the gears, but not overly quickly. Definitely wasn't pushing it too hard.
Took it to the local garage and they didnt even want to touch it because it involved the turbo. The guys just reset the codes and sent me on my way. Told me I should find a performance shop to take it to.
Can anyone give me any advice? The codes all involve sensors with either a high or intermittent circuit. You guys haven't failed me yet, hoping to get some more good advice on this new, interesting problem.
Old Jul 14, 2014 | 11:48 AM
tomj77's Avatar
I know the maf and one of the map sensors are also temp sensors. Since u also have a boost code I'd lean toward ur map sensor needs replacing. But idk someone who knows more about these chime in. It's either the map or maf that seems to have taken a dump. Maybe ur boost sensor on the turbo as well. I'm sure it's one of the 3
Old Jul 14, 2014 | 07:34 PM
Okay, thanks. I figured it was a sensor, not a problem with the actual systems themselves. Anyone else able to help narrow this down a bit?
And is it safe to drive? The guy just sent me on my way and I am assuming its okay, but it seems prudent to ask the question.
Old Jul 14, 2014 | 07:42 PM
tomj77's Avatar
Does ur boost gauge work when the code pops up?
Old Jul 14, 2014 | 10:01 PM
yes the gauge works but i'm only getting mechanical boost
Old Jul 14, 2014 | 11:33 PM
tomj77's Avatar
oh figured u had stock electrical gauge cause that would tell u if its the map sensor. ......wait I just looked at the codes again and it is intake air temp sensor 2. which is the map sensor on the lower charge pipe. check to see if wires are ok, if they are replace it. should fix it. that is ur map and temp sensor 2. I believe that is ur problem.
Old Jul 15, 2014 | 07:25 AM
great thanks! two questions (from a noob)
Where do I purchase said sensor?
Where is it/ anything important I need to know about replacing it?
Old Jul 15, 2014 | 10:59 AM
umrdyldo's Avatar
SENSOR ASM-INT AIR PRESS & TEMP 12592017
Stock MAP sensor
Old Jul 15, 2014 | 11:25 AM
tomj77's Avatar
It is on the charge pipe that runs from passenger side intercooler to the throttle body. Open ur hood, look down by the rad fans that pipe u see going into throttle body, it's only sensor on there.
Old Jul 15, 2014 | 12:32 PM
sweet! Thanks!
Old Jul 16, 2014 | 10:21 AM
Just popped the hood to double check the part number before purchasing the non-returnable part.
The sensor on my car is a Bosch part numbered 0281002845. Am I looking at the right thing?
Old Jul 16, 2014 | 01:42 PM
tomj77's Avatar
If it has blue label then it's the stage 1 sensor. If no one answers by time I get home I'll check
Old Jul 16, 2014 | 02:52 PM
jpunishment's Avatar
yep thats a stage 1 sensor
GM ACDelco - GM Stage 1 Sensors #
Old Jul 16, 2014 | 04:49 PM
Its interesting to find out what all has been done to the car before I purchased it. This is the second aftermarket part that has given me trouble, neither of which I put on. So do I need to replace it with one of these?
Also, does this mean I have an upgraded PCM? The product description for the upgraded MAP sensors says that it requires ZZP LNF 1.0 PCM. JUst looked at mine and it isnt marked in any way as something special.
Old Jul 16, 2014 | 06:56 PM
tomj77's Avatar
U could have gms1 tune on the car, how high do u boost?
Old Jul 16, 2014 | 07:01 PM
Yes if you have those sensors you some sort of tune most likely gms1 I would just replace the sensor and see how the car runs . You can get the sensor from zzp but I think you can buy them individually from auto parts store for a lot cheaper hopefully someone else can chime in on where to get it . I bought mine from that zzp link
Old Jul 16, 2014 | 07:41 PM
tomj77's Avatar
here ya go, $20 bucks
3 Bar MAP Sensor 55206797
Old Jul 16, 2014 | 07:42 PM
tomj77's Avatar
it has the same part number on the sensor itself that u saw. but the sku is different but that's the one.
Old Jul 16, 2014 | 07:44 PM
tomj77's Avatar
its retarded how much acdelco charges for the stock sensors. the stage 1 sensors are way cheaper. lol
Old Jul 16, 2014 | 10:11 PM
I'm getting approx 18 lbs of boost. So its nothing crazy. The car has since run fine. But I do have some longer drives coming up, mainly a long run from Maryland to OBX in a few weeks, so I want to get it taken care of. My question is that is there any harm being done to the car if I continue to drive with the sensor occasionally acting up?
Also, do I change the sensor that is directly on the throttle body or the one on the pipe down below that we have been discussing?
Old Jul 16, 2014 | 10:30 PM
tomj77's Avatar
there is no sensor on the throttle body. there is one on the intake manifold and one on the charge pipe. change the one on the charge pipe. 18 lbs of boost? that doesn't seem like gms1. but could be due to elevation or whatever. 18 lbs of boost seems like stock tune or an aftermarket tune. if it is stock tune, that could be why the codes are popping. u cant use the gms1 sensors with stock tune for that reason. where did u get the car? dealer or private. if it was from dealer go back and tell them to see if the gms1 tune is on there. if it was from a guy, ask what tune he has on it. if he tuned back to stock before he sold it to u, u gotta either get stock sensors or u have to get a tune to get ride of the codes.
to answer ur question, no it wont do any harm to the car to run like that, will just be a pain in the butt.
Old Jul 17, 2014 | 07:47 AM
Okay. Now you are beginning to understand why I am confused with this car hahaha. It's been a few months so I'm not sure why this is happening now all of the sudden.
I bought it used from a Subaru dealership. Next time I'm over that way I guess I need to just ask them whats going on with it.
Really glad to know that it is safe to drive even with this problem. That was my biggest worry.
Old Jul 17, 2014 | 11:15 AM
tomj77's Avatar
If be better off going to a Gm dealer, don't think subi dealer can see what tune u got on there. But if it's been good for months it's definitely the sensor. Try that of it still does it then goto Gm and they will tell u better what's going on. Or if u got someone with hp tuners close by could pull the tune and send it to someone that tunes these cars from the site and they can tell u what tune it is
Old Jul 17, 2014 | 12:56 PM
Sensor it is. Thanks!
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
