Random Misfire
Old Mar 27, 2011 | 04:21 PM
hunter19707's Avatar
Random Misfire
I need help toubleshooting. My car has not thrown any CEL's and my gauge is showing intermittent misfires. At times there are misfires with hesitation, pop from the exhaust, and times with nothing but the gauge indicating a misfire. I put stock plugs back in and still the same issue. Cleaned the maf, didn't help. A week and a half ago, I had the oil leak by the high pressure fuel pump fixed(cam position sensor). I haven't noticed any misfire issues up until that point. Also, I put in the Forge BPV about the same time. Any ideas on what else I should check out before I give up and take it to the dealer. No gaurantees they'll find the problem either.
Old Mar 27, 2011 | 04:30 PM
BlackLsCoupe's Avatar
i got the same issuse but it runs fine, i regapped the plugs and it still does it. im guessing its normal with a high boost tune.
Old Mar 27, 2011 | 04:53 PM
The thing is that I've been tuned for a while and just noticed it happening a few days ago. I guess I could log it and have Vince take a look to see if he has any ideas.
Old Mar 27, 2011 | 04:58 PM
he never found anything wrong with mine, plus it happens when cold out like yesterday was 32* i ran a TC sedan gave him a double blast of carbon back fires lol
Old Mar 27, 2011 | 08:17 PM
meckel's Avatar
Mine does it too, sounds similar to your situation actually, I wouldnt worry about it, I sent logs to Vince and he said its completely normal.
Old Mar 28, 2011 | 01:08 AM
Ok, on my way home from work I was watching my gauge and it showed multiple misfires on all cyl. There were up to seven of them one time before it reset. Also, my engine seems to be running hotter than usual at 200-205 degrees F. The temps normally run at 192 degrees. Ambient air was 23 degrees.
Any ideas?
Old Mar 28, 2011 | 02:05 AM
jarhead's Avatar
I have seen the random ghost misfires on 3 ss/tc's that two had interceptors one had dashhawk. My car does it moslly on startup doesn't matter if flashed back to stock tune or not, it was always random cyl. If it was a lot only in one cyl or enough to set a cel then I would worry about it. One of the auto x guys here says he has less with one step colder plugs, I have tried 3 different kinds of plugs made no difference on mine. I think they all do it just nobody watches for it all the time once I started watching it I noticed it. Then I set it to monitor total misfires and also how many per cyl. I have never felt any either if misfires were severe in a car you usually feel them chug a little when it happens. I think c.millers car has it also If I remember correctly I think he mentioned it was at a lower rpm just when you shift from 2nd to 3rd was when my car did it sometimes also. Also Term and I am broke I have seen mention it also. Another thing is I do not think no matter how tight you get the stft's did not eliminate it either. I have not monitored it since having the cat warm up delete to see if it reduced them on startup or not.
Old Mar 28, 2011 | 02:48 AM
07SSYellow's Avatar
Resident Post Whore/Troll
i had this prob too, it went away on its own though, still does it every once in a while but its not normal anymore
Old Mar 28, 2011 | 02:59 AM
jarhead's Avatar
Hey good to see ya, You coming back through this way again anytime soon? Yeah it was never a give in would change up when and how many times it did it sometimes would not have any and I would think it was gone then sometimes just 1 misfire here and there. I would love to hear from anyone who has never had any ghost misfires on there lnf car ever who were monitoring for it and by cylinder also?
Old Mar 28, 2011 | 03:28 AM
jarhead's Avatar
The random ghost misfires I have had in the past had no hesitation or pop from the exhaust, That suggests yours are real. I have not heard of anyone else having problems from the forge bov. Did you put the green I think it was spring in? Some have problems with the heavier dejon spring or the forge heavier spring whatever color that was? Weird it started at same time as you installing it though. I have been thinking about getting that forge also.
Old Mar 28, 2011 | 03:30 AM
I have felt it hesitate or chug at least twice, that is why I started monitoring them. I never noticed it before. Maybe I am some kind of hypochondriac. I'm gonna try a few things tomorrow, even though they may be futile. Yep, green spring.
Old Mar 28, 2011 | 03:38 AM
ryansalazan's Avatar
try seafoaming and cleaning out your injectors. i had massive amounts of missfires and nothing looked wrong so took it in, turns out the injectors were just dirty
Old Mar 28, 2011 | 03:41 AM
07SSYellow's Avatar
hey! haha ya ill try too soon, gotta alot of recovering to do from surgery first..sorry for cluttering your thread
Old Mar 28, 2011 | 03:44 AM
Picked some up on the way home from work tonight, on my list of things to try. I put some injector cleaner in it on my way home as well. Just want to use the seafoam in the IM.
Old Apr 29, 2011 | 03:31 PM
IsItFast?'s Avatar
Sorry for bringing back an month old post - any updates on this? Did injector cleaner/seafoam help your misfires?
Old Apr 29, 2011 | 04:41 PM
SSlobalt's Avatar
Did you rev really high in the RPM range at any point before this issue?
Old Apr 29, 2011 | 08:43 PM
Haven't experienced any more hesitation. I did seafoam and put in new plugs, but the gauge still reads random misfires. Vince told me nothing to worry about unless I throw a code. Off topic: My car runs great now that I replaced my slave cyl. that was installed with my new clutch in Feb. I spent an additional 832.00 to replace a slave cyl. that was 2 months old. Dyno Day is next Sat., I get to see what I'm putting down without any slippage this time.
Not that I recall.
Last edited by hunter19707; Apr 29, 2011 at 08:43 PM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
jmelton327
Sep 26, 2015 10:04 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
