Random misfire codes?
Old Mar 14, 2012 | 10:06 PM
Iturbo's Avatar
Around 48,000 miles. Check engine light appeared about a week or two ago. Ran codes at autozone....cylinder 2, 3 I believe claiming to "misfire". I hear no misfire and car still runs like a champ. I read quite a few cobalts are doing this so what have you done to fix it? Just cleared the code?
Old Mar 14, 2012 | 10:12 PM
tomj77's Avatar
clear the code, mine does it on startup once in awhile, car sound doesnt change. dont know why it do it. but mine only registers on the dashdaq, doesnt set off engine light at all.
Old Mar 15, 2012 | 08:02 AM
Iturbo's Avatar
Yeah I guess i'll just clear it. Appreciate the feedback
Old Mar 15, 2012 | 09:15 AM
sebleroux08/tc's Avatar
this x2 ! Do you have a trifecta tune ? Mine set off my engine light everytime but its never more then three cylinders at a time
Old Mar 15, 2012 | 10:45 AM
tomj77's Avatar
I should add it doesn't register as a code either. Just clear it so it goes off the dashdaq screen, otherwise when I scan it it finds nothing, and ya I do have trifecta. I'd like to hybrid the tune with hp tuners but I'm to cheap to buy it
Old Mar 15, 2012 | 11:05 AM
nobody2u's Avatar
My car was doing it for a while in cyl 3. Dealer tried replacing the plug and ignition coil; no luck. They then replaced the injector under warranty and the code hasn't come back since.
Old Mar 15, 2012 | 11:11 AM
Iturbo's Avatar
I have no tune at all so its weird but I'm just going to replace my injectors then
Old Mar 15, 2012 | 08:31 PM
Yea same here hp tuners are def much better and with the option of having two tunes its even better , unfortunetly were I am ottawa ontario dosent seem like many people are very good at this/ will stand behind there tunes as much as some do on this site! I dunno how it wouldn't register as a code tho? Seems odd its getting annoying tho I think I will start by changing the plugs
Old Mar 15, 2012 | 08:54 PM
tomj77's Avatar
im pretty sure its just fake misfire. if i wouldnt have my dashdaq id never even see it. when i took my cat off and went catless dp, it hardly ever did it, recently put it back on and its been starting again. so off it comes again lol
Old Mar 16, 2012 | 12:38 PM
hucks1987's Avatar
i just had this problem, took it in they have to change out the piston and rings. i had 60k miles.
Old Mar 16, 2012 | 01:43 PM
Chevrolet Cust Svc's Avatar
I'm not sure when you were going to get a chance to do this, but hope that everything goes well and that the misfire code is resolved.
Sarah
GM Customer Service
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Extremespeed
Sep 29, 2015 04:34 AM
jmelton327
Sep 26, 2015 10:04 PM
