Recently just bought hahn charge pipes
Old Jan 12, 2013 | 10:17 AM
JetLAGG's Avatar
Hey, everyone. I was wondering if anyone here still has hahn charge pipes. I recently bought some for cheap from a guy in my area. The thing I've been reading is that they put a dent in your hood. Is there a way around this? For example, cutting the charge pipes a little to avoid this issue?
Old Jan 12, 2013 | 03:11 PM
Nfamous60's Avatar
no i have hahn charge pipes the pipe doesnt put a dent in the hood the screws from the clamp do becuz the pipe connect from the turbo ti the upper pipe is kinda of big, turn the screws facing down and its a easy fix look at mine. the 1st pic has them up and thats wut hits the hood/ the second pic their down and no problem.
if u look at the hahn coupler the screw to tighten it i have under the pipe to clear the hood but if u can see the middle of my hood i already have a dent.
Old Jan 12, 2013 | 03:20 PM
prevsrt4owner's Avatar
Yep, seems like an easy fix. Rotate the clamps downward for more clearance.
Old Jan 12, 2013 | 03:27 PM
occsdude's Avatar
i have no problem with mine but i made sure all my clamps were pointed down and away from my hood
Old Jan 12, 2013 | 03:45 PM
tomj77's Avatar
i have the upper one, got rid of lower cause it rusts on the inside due to not being alumunum or stainless
Old Jan 12, 2013 | 06:08 PM
Frogstofall's Avatar
The upper is though?
Old Jan 12, 2013 | 06:32 PM
JetLAGG's Avatar
Whoa...I have the lower pipe also. Really, it feels like aluminum. Is there a way tell if or better yet, what type of metal it is?
Also, thank you Nfamous for quick response and needed info.
Old Jan 12, 2013 | 07:15 PM
Put a magnet on it. Aluminum is not ferrous.
Old Feb 14, 2013 | 09:18 AM
NickD's Avatar
Yep, what everyone else said. Make sure those clamps are away from the hood, also make sure the larger pipe is fully seated in the elbow so it doesn't rub the hood on shifts.
deviance
Nov 24, 2015 05:51 PM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
