Replacing pistons while engine still in car?
So i am gathering parts for my cams swap. I was wondering if is it possible to replace the pistons while the engine still in the car? I could figure dropping the oil pan and unbolting the rods from the crack then pushing piston up through the cylinder. Has anyone done this?
Yes you can replace the pistons with the engine still in the car. But if you're going with aftermarket pistons (Or OEM, but especially aftermarket), then it's best to pull the engine out and get it honed. Proper piston-to-wall clearance can make or break an engine.
As everyone else is saying, when you go to a forged piston the clearance will need to be a little wider then the stockers. Also if you just do a little clean up hone there will be debris and theres no way to really clean the inside of the motor properly at that point.
No point in blowing a good LDK block in "hopes" it will hold . when you can for sure put a few hundred into it and make it pretty close to bullet proof
Turbo Johnny
Feb 21, 2019 09:41 AM
Adam144
Sep 3, 2015 07:48 PM
