Replacing pistons while engine still in car?
Old Nov 14, 2013 | 08:58 AM
Robssturbo's Avatar
So i am gathering parts for my cams swap. I was wondering if is it possible to replace the pistons while the engine still in the car? I could figure dropping the oil pan and unbolting the rods from the crack then pushing piston up through the cylinder. Has anyone done this?
Old Nov 14, 2013 | 09:01 AM
thats how the ecotec build book says to do it.
Old Nov 14, 2013 | 09:04 AM
WSFrazier's Avatar
It's how I've built all my ecotecs. Easy-peasy.
Old Nov 14, 2013 | 12:54 PM
Fastgti69's Avatar
Dont forget to hone the block. I believe you'll need a new oil pump too when you do this.
Old Nov 14, 2013 | 01:09 PM
reportedly, dropping the cradle isn't too hard though. but id rather not do that either haha
Old Nov 14, 2013 | 07:36 PM
TStone's Avatar
Yes you can replace the pistons with the engine still in the car. But if you're going with aftermarket pistons (Or OEM, but especially aftermarket), then it's best to pull the engine out and get it honed. Proper piston-to-wall clearance can make or break an engine.
Old Nov 14, 2013 | 08:58 PM
Omiotek's Avatar
have the engine properly honed out of the car.
Old Nov 14, 2013 | 09:35 PM
cmiller8006's Avatar
As everyone else is saying, when you go to a forged piston the clearance will need to be a little wider then the stockers. Also if you just do a little clean up hone there will be debris and theres no way to really clean the inside of the motor properly at that point.
Old Nov 15, 2013 | 08:06 AM
AARON-SS-TC's Avatar
well, for the $600 for the pistons, and at least a $1000 for labor and misc. parts, then just get a new ldk motor, and be done with it...
Old Nov 15, 2013 | 09:27 AM
Omiotek's Avatar
ldk internals arent bullet proof. the blocks very solid and the internals are better in my opinion but they still arent as strong as forged internals
Old Nov 15, 2013 | 11:53 AM
PrincessTurbo's Avatar
Ive got an LDK , it isnt seeing any other turbo until its got forged rods and pistons with valve springs and fueling, sorry
No point in blowing a good LDK block in "hopes" it will hold . when you can for sure put a few hundred into it and make it pretty close to bullet proof
Old Nov 15, 2013 | 12:38 PM
Fastgti69's Avatar
I still want to see some dynos or logs of that GTX on your LNF bro..
Old Nov 16, 2013 | 04:29 AM
mongorat427's Avatar
How about a gen 3 2.1 LNF based on a 2012 2.4 block. Girdled from the factory
Size:  151.1 KBName:  DSC_0019_zps4c0884fe.jpg
GaryGibblez
Jan 14, 2020 10:35 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
vjoel2011
Oct 2, 2015 12:11 PM
Adam144
Sep 3, 2015 07:48 PM
