Running dp on tune necessary + add't
Old May 16, 2010 | 06:03 AM
Soofisahab's Avatar
All,
I know there have to be a few out there running a tune w/o a dp. I also know there is 10-15 hp in a dp, but is it absolutely necessary?
Right now I'm dumping all my spare cash into my business, but the thought of 300 hp on a 22 psi Trifecta tune is calling me....budgeted $200-$300 for car upgrades this month, next month, and so on....
I wanna get the tune first and dp later, but logic tells me I'd have to retune for the dp. What is the tuning process for subsequent mods? Do I pay the full tune price to retune for future mods? Does purchase of the obd-usb cable come with unlimited retunes for future mods?
Old May 16, 2010 | 08:22 AM
SSlobalt's Avatar
Although it's not completely necessary to retune for a dp, but it is required to get the most power out of it. I believe, if you use Trifecta, it's only 50 bucks to adjust your current tune for any additional mods.
Old May 16, 2010 | 09:01 AM
02RedWS6TA's Avatar
If you have the EZflash cable the retunes for that stuff are free. Also, I just sent him my logs after adding a DP and upper CP and he said he didn't need to make any changes. I told him before he made my first tune though that I was going to be adding them within a weeks time so he may have adjusted for it right then.
Old May 16, 2010 | 11:13 AM
tomj77's Avatar
or buy the cable from trifecta and all ur tune adjustments will be free.
Old May 16, 2010 | 12:17 PM
Soofisahab's Avatar
Thanks for the info. Def goin' for the cable.
Old May 17, 2010 | 03:04 PM
wantedSS/TC's Avatar
DP is the single most important bolt on for this car. frees it up so much.
gets rid of the 2inch crimp and 2 cats!
Old May 17, 2010 | 03:47 PM
northvibe's Avatar
just did my dp saturday. Rallyracer and I took pics of the cats..its no wonder the stock flows so bad :P I got a catted dp but after a few pulls I could feel a slight difference, louder as well.
Old May 17, 2010 | 03:51 PM
Yeah, they're pretty easy to put on. It's just one bolt that holds everything up. If I had access to a lift, I could swap it out in 10 minutes, but lying underneath a car on jacks takes roughly 35 minutes.
Speaking of, I need to swap my Dp. I have inspection coming up and we're inspected for emissions here in my part of PA.
Old May 17, 2010 | 04:45 PM
Supercharged Guy's Avatar
Ouch that sucks, but the good part is it doesnt take long at all
Lick and stick up here
Old May 17, 2010 | 04:49 PM
yeah, if only it was that easy!
Old May 17, 2010 | 05:18 PM
Sweetsandman's Avatar
Didn't need to make any changes?! Wtf? When I added my charge pipes my fuel trims were off a good bit and when I put my dp on I changed a good bit.
Old May 17, 2010 | 05:40 PM
umrdyldo's Avatar
Which direction does it skew the fuel trims?
I figure with a 3-5% power increase you would see a big change in fuel trims.
Old May 17, 2010 | 06:03 PM
The direction varied by the MAF frequency but they most certainly required some correction.
Old May 17, 2010 | 06:22 PM
northvibe's Avatar
how do you take off/on the o2 sensor without twisting up the wires?
Taking off the dp I spun the stock pipe. But putting on the new dp spinnging the pipe didn't help a ton.
Old May 18, 2010 | 12:32 AM
T-Man's Avatar
I've heard to un-clip it from the harness first and then use an 02 socket.
Old May 18, 2010 | 03:38 AM
SSlobalt's Avatar
Unclip the O2 sensor from the harness. It's accessible through the driver's side wheel well. Unwrap the wiring from the heatshield. Pull the O2 out with the downpipe and detach with it out of the car. Attach O2 to new pipe before putting it in the car. I have pics of this in a thread, but it got deleted for some damn reason. I'll put up pics when I get home in the morning. Can't do it at work.
Old May 18, 2010 | 10:23 AM
SSlobalt's Avatar
Here's a pic of the O2 harness connector from the driver's side wheel well. YOu have to pull that little blue lock out of the connector, then you can separate the male from the female.
Unwrapping the O2 sensor wiring from the heatshield is easy.
Pull the pipe and O2 sensor/wiring out as one piece.
Reinstall sensor in new pipe before putting it in the car.
Old May 18, 2010 | 10:31 AM
SSLOW's Avatar
what companies dp is that?
Old May 18, 2010 | 05:01 PM
^^ sslowbalt has it right on!
Same method, only I didn't take pictures.
Old May 18, 2010 | 05:09 PM
Tofu's Avatar
My fuel trims were way off after I added my DP, I had to retune to adjust.
Old May 18, 2010 | 05:18 PM
crypticscifer's Avatar
un-clip/
Old May 19, 2010 | 03:32 AM
SSlobalt's Avatar
ZZP catted. My buddy's car.
Old May 19, 2010 | 10:01 PM
SSLOW's Avatar
ahh, ok.
chefhhr
Oct 26, 2015 10:36 PM
Hugger1975
Oct 15, 2015 03:28 PM
CudaJoe
Oct 5, 2015 11:56 PM
twilson380
Sep 14, 2015 10:52 AM
SS_2009_TC
Sep 4, 2015 10:48 AM
