Running E85
Old Sep 27, 2010 | 04:24 PM
paintballerr78's Avatar
Running E85
Well today i found out there are actually gas stations around me with e85. I know i need to run a mixture 50/50 of 93 octane and e85 what if i ran 92octane and e85 will it still be the same cause there are no gas stations around me with 93 all they have is 91 and on base has 92. Also i know i need a tune and i have a trifecta now would i just tell them i need it updated to run e85
Old Sep 27, 2010 | 05:49 PM
peachpuff's Avatar
Best to get in contact with him yourself, and maybe he can add the e85 tune as a secondary tune when your not running e85.
Old Sep 27, 2010 | 06:48 PM
yamaha288's Avatar
how do you plan on mixing it 50/50 lots of gas cans?
Old Sep 27, 2010 | 06:53 PM
Iam Broke's Avatar
Two card swipes, 5 gals each works fine for me. He will have to adjust your MAF freq table +14% to compensate as a starting point and relog.
91 - 93 pump gas with it is fine.
Old Sep 27, 2010 | 09:31 PM
i think im gonna run a tune for normal gas then one for e85 mixture
Old Sep 30, 2010 | 12:13 PM
is it safe to run the mixture without a tune at first. Im going to do the mix and do a datalog and send it to vince and hes going to create me a tune
Old Sep 30, 2010 | 12:19 PM
Dirty25RS's Avatar
Dont put E85 in your car without a tune. If its 100% E85 you'll run 30% lean, if its 50% E85 you'll run 15% lean.
Whats the basis for mixing it 50/50 with gas again?
Old Sep 30, 2010 | 12:33 PM
what if i run it with a trifecta tune but its not tuned for e85
Old Sep 30, 2010 | 12:41 PM
383_Stroker's Avatar
its not safe to run e85 unless your tuned for it.. el fin
Old Sep 30, 2010 | 02:27 PM
Iam Broke's Avatar
Tell Vince to start by multiplying the MAF freq by 1.15 across the board for the 1:1 mix. (E48 btw if your 93 is 10% E already)
Old Oct 3, 2010 | 11:16 AM
i looked at local gas stations i only found e85 and i think it said 70% ethanol
Old Oct 3, 2010 | 11:25 AM
LE5_AJ's Avatar
it said a minimum of 70% and the reasoning for that is during the winter they back off to a 30/70 mix of regular gas and Ethanol to help the car's start during the winter.
also off topic i bet i could smoke you in some paintball :p
Old Oct 3, 2010 | 11:27 AM
Alright ahha i wasnt sure....Idk maybe you could i played PSP for 3 years what about you played d3 5 man xball
Old Oct 3, 2010 | 11:34 AM
LE5_AJ's Avatar
lol well i've played for about 9 years now but it been a lot of woodsball and 3 years of some speedball now but especially recently i haven't gotten to play much because of work and school and it's a 4 hour drive to the field.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Builttss
Oct 4, 2015 10:21 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
