Seafoam vs B12 chem tool ????
Old Feb 20, 2014 | 10:27 AM
mysweetSS's Avatar
Hey Guys,
I was wondering if anyone can educate me on what the difference between Seafoam and B12 chem tool. A buddy who has a Lincoln LS was saying that on thier Lincoln forum that B12 chem tool worked better than Seafoam. Since i never tried either, i was hoping someone could chime in with what they know on both of them and expeirences they had with both. I am looking to use one of them before my next oil change in a few weeks.
Seafoam:
Amazon.com: Sea Foam Motor Tune - Up: Automotive Amazon.com: Sea Foam Motor Tune - Up: Automotive
B12 Chem Tool:
Berryman 0116 B-12 Chemtool Carburetor/Fuel Treatment and Injector Cleaner - 15 oz. : Amazon.com : Automotive Berryman 0116 B-12 Chemtool Carburetor/Fuel Treatment and Injector Cleaner - 15 oz. : Amazon.com : Automotive
Old Feb 20, 2014 | 11:39 AM
umrdyldo's Avatar
Are you talking about cleaning the valves or are you talking about just running some through the intake manifold in hope it will clean valves?
It has been tried and tried again. Seafoam will not due **** on our intake valves if you are hoping to just spray some through the manifold.
Our valves require walnut shell or a full soaking in chemical.
Seafoam, B12 chem, and GM upper engine cleaner should all work for that.
Old Feb 20, 2014 | 12:49 PM
frdfandc's Avatar
I've been a big proponent of Seafoam or the Lucas fuel system cleaner. I use them every 4-5k miles. Helps control the moisture in the fuel system caused by the Ethanol fuels.
As a former mechanic, I've always shyed away from additives, but Seafoam and Lucas really work.
Old Feb 20, 2014 | 12:59 PM
umrdyldo's Avatar
As long as the car isn't sitting for long periods then this is not an issue at all.
Old Feb 20, 2014 | 03:03 PM
frdfandc's Avatar
Ethanol is prone to attract moisture and cause corrosion, can can happen during transport from the refinery to the station. Ethanol can still cause issues, no matter how much you drive your vehicle.
So using a quality fuel system treatment can help prevent issues in the long run.
Old Feb 20, 2014 | 03:09 PM
umrdyldo's Avatar
We have a ton of high mileage cars on here and I have never heard of this once.
Now generators, atvs, etc. Vehicles that sit, have tons of issues with ethanol.
A vehicle that is going through a tank a weak won't see crap. The only issues we have are the 08-09 LNFs that have injector seal issues with E
Old Feb 20, 2014 | 03:59 PM
frdfandc's Avatar
You have to keep in mind that forum members (no matter what type) only constitute a small portion of the general population. Most people won't see problems, but it does happen.
We have 65+k members on this board, but there were over 1.1 million Cobalts produced. Not including the Delta platform models. So real world numbers will be greater than what you see on a forum.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
DocSvensk
Sep 27, 2015 02:24 PM
GoodSpeed150
Sep 21, 2015 01:57 AM
