Is Sensor Calibration Stored in the ECU
Hello all,
I had my steering sensor recalibrated at the dealer as it was causing the ESC to wrongfully activate. Problem fixed!
I have two ECUs; one tuned one stock (the one that came with the car).
When I had the sensor recalibrated, I had the stock ECU in.
One question is, when I put the tuned ECU back in, will I have any problems with the sensor? Is that info stored somewhere else?
Thanks!
Thanks!
Yes the Steering angle and Yaw sensor values are stored in the BCM and the Brake pressure transducer data for the EBCM (electronic brake Control Module) is stored in the EBCM. When that relearn process is done those values are reset.
Thanks!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
