Shell URT with the possibility to be better than E...
Yes ZZP cams with fuel lobe. Its a AGP turbo. about the size of the zzp s256ext but with a larger exhaust side and dual ball bearing. Its ryan salazan's build on here, you can check it out. I would like to test some c16 and E85 mix in his car to see what we could get out of it. C16 is like $14.00 A gallon down here.
There is quite a bit left. He dynoed 502hp on 25.5psi. It runs 30psi on the street and doesnt show a signs of giving in. Thats as far as I have pushed it because the stg1 3bar maps are about maxed at that point. We will see how far it can go after he moves up to a 4bar set up.
Damn, thats not bad. This is from a dealer in Tennessee, like right across the state border between West Virginia and Tennessee. Maybe they're getting it from MD? Lol!
I have a LNF down here running 100% e85 and made a little over 500whp on 25psi without zzps fifth injector. Its tuned for 30psi on the street and almost never gets a misfire due to the injection timing. Usually gets one or two when it lights up the tires in second gear and it taps rev limiter at 7200 but thats about it.
If outperforms C16 without lead. It has a higher detonation resistance than C16.
That's a cost savings (no frequent replacing of O2 sensors, no damage to cats).
Unlike C16, it runs well even on a stock timing curve, even at idle and part-throttle (good if your car sees street and track time and often has a mix of fuel in the tank).
It's a better fuel all around for near the same price.
Some very high profile shops/racers are running this stuff (Shell URT Advanced) now and swear by it.
Yeap, here's a new 2013 GT500 with just simple bolt ons like exhaust, intake, and pulley in the 9s trapping 142 running Shell URT Advanced.
First 2013 Shelby GT500 In The 9's - 9.95@142MPH - YouTube
How is that even possible? Full E-85 and 500 whp without a 5th injector? I have a 2871 car at 26 psi that is right on the edge of injection window misfire above 6500 RPMs and it is running 93 octane no ethanol. Do you have a screen shot of this car doing a pull? Because the IDC would be over 50% and the IPW would be over 8 ms up top when there is only ~ 5ms of injection window.
go ahead and mix leaded race fuel with ethanol and see what happens to it.
I can get my hands on 5 gallon pails of this stuff that can be drop shipped right to your door but I have to order 10 pails at a time. If we get a few guys interested id be willing to order some pails.
i dont have the hptuners screenshots, that would be something silverbullet would have. But if you look at my build thread theres a video in there of the dyno pull pulls hard but smooth throughout the entire rpm range. i will def be trying this fuel out tho with a retune, new map sensors and once my 3rd gear is fixed lol.
Must be magic LOL. Forty's stock turbo sky on E-85 with ZZP's cams with HPFP lobe. Car makes ~370 whp 410 wrtq at 24 psi. This pull shows 7.5 Ms injection time at 6000 RPMs and this is with slightly raised fuel pressure and advanced injection timing as well. Injection window is only ~6mS at 6000 RPMs. It has some minor injection window misfire in this log.
