Shell URT with the possibility to be better than E...
Old May 30, 2012 | 12:56 AM
ATLsilverSS's Avatar
Originally Posted by silverbullet08
Yes ZZP cams with fuel lobe. Its a AGP turbo. about the size of the zzp s256ext but with a larger exhaust side and dual ball bearing. Its ryan salazan's build on here, you can check it out. I would like to test some c16 and E85 mix in his car to see what we could get out of it. C16 is like $14.00 A gallon down here.
yeah i think i remember zzp saying that the injectors do eventually max out at xxx hp. don't remember when tho. how much fuel and inj timing do you have left with it?
Old May 30, 2012 | 12:26 PM
silverbullet08's Avatar
There is quite a bit left. He dynoed 502hp on 25.5psi. It runs 30psi on the street and doesnt show a signs of giving in. Thats as far as I have pushed it because the stg1 3bar maps are about maxed at that point. We will see how far it can go after he moves up to a 4bar set up.
Old May 30, 2012 | 09:29 PM
Maven's Avatar
Theres a place in MD, that sells Shell URT, Advanced is like $535 for a 55drum. its shipping that really kills you.
Old May 31, 2012 | 01:01 AM
FasterIsBetter's Avatar
Damn, thats not bad. This is from a dealer in Tennessee, like right across the state border between West Virginia and Tennessee. Maybe they're getting it from MD? Lol!
Old May 31, 2012 | 01:03 AM
What I'm wondering is how we would get a 4 Bar map sensor without going aftermarket. Couldn't he just get a 35+psi boost gauge and monitor the pressures from that? I believe that's how lots of other tuners do it.
Old May 31, 2012 | 01:09 PM
Terminator2's Avatar
I have a LNF down here running 100% e85 and made a little over 500whp on 25psi without zzps fifth injector. Its tuned for 30psi on the street and almost never gets a misfire due to the injection timing. Usually gets one or two when it lights up the tires in second gear and it taps rev limiter at 7200 but thats about it.
How is that even possible? Full E-85 and 500 whp without a 5th injector? I have a 2871 car at 26 psi that is right on the edge of injection window misfire above 6500 RPMs and it is running 93 octane no ethanol. Do you have a screen shot of this car doing a pull? Because the IDC would be over 50% and the IPW would be over 8 ms up top when there is only ~ 5ms of injection window.
Old May 31, 2012 | 01:51 PM
EXsoccer1921's Avatar
i'll stick to my 110 for 7.95
Old May 31, 2012 | 03:15 PM
I wish 110 was that cheap here. Its like $10-12 a gallon here for Sunoco 110. Might as well go URT for that price. Luckily though I found Ethanol by my camp, which will give me a good reason to go camping more often, lol.
Old Jun 11, 2012 | 03:10 PM
JimDDD's Avatar
Originally Posted by FasterIsBetter
Welp, bad news. Just got a PM from the dealer. $744 for a drum of it. Definitely not worth it guys, my apologies if I got your hopes up! That equates to about $13 a gallon, around the same price as C16.
It's often a little less than C16, but even at the same price, consider this:
If outperforms C16 without lead. It has a higher detonation resistance than C16.
That's a cost savings (no frequent replacing of O2 sensors, no damage to cats).
Unlike C16, it runs well even on a stock timing curve, even at idle and part-throttle (good if your car sees street and track time and often has a mix of fuel in the tank).
It's a better fuel all around for near the same price.
Some very high profile shops/racers are running this stuff (Shell URT Advanced) now and swear by it.
Old Jun 13, 2012 | 02:34 AM
Yeap, here's a new 2013 GT500 with just simple bolt ons like exhaust, intake, and pulley in the 9s trapping 142 running Shell URT Advanced.
First 2013 Shelby GT500 In The 9's - 9.95@142MPH - YouTube
Old Jun 13, 2012 | 01:17 PM
  #36
Area47's Avatar
Rent me! per hour
******* magic! and you know this. man.
go ahead and mix leaded race fuel with ethanol and see what happens to it.
Old Jun 13, 2012 | 01:33 PM
  #37
Frogstofall's Avatar
Are you suggesting that it's bad or good? I know people who do it with no I'll effects. Would like to hear more.
Old Jun 13, 2012 | 03:42 PM
  #38
Sully20's Avatar
Old Jun 13, 2012 | 07:40 PM
  #39
Area47's Avatar
Rent me! per hour
if it's used instantly. it will be fine. if you let it sit in the tank for a week, you will have ruined both fuels.
Old Jun 13, 2012 | 10:50 PM
  #40
BNRacing's Avatar
I can get my hands on 5 gallon pails of this stuff that can be drop shipped right to your door but I have to order 10 pails at a time. If we get a few guys interested id be willing to order some pails.
Old Jun 14, 2012 | 01:47 AM
  #41
Ah okay gotcha. Thx.
Old Jun 14, 2012 | 01:05 PM
  #42
Must be magic LOL. Forty's stock turbo sky on E-85 with ZZP's cams with HPFP lobe. Car makes ~370 whp 410 wrtq at 24 psi. This pull shows 7.5 Ms injection time at 6000 RPMs and this is with slightly raised fuel pressure and advanced injection timing as well. Injection window is only ~6mS at 6000 RPMs. It has some minor injection window misfire in this log.
Old Jun 14, 2012 | 01:33 PM
  #43
ryansalazan's Avatar
i dont have the hptuners screenshots, that would be something silverbullet would have. But if you look at my build thread theres a video in there of the dyno pull pulls hard but smooth throughout the entire rpm range. i will def be trying this fuel out tho with a retune, new map sensors and once my 3rd gear is fixed lol.
Old Jun 14, 2012 | 05:13 PM
  #44
Some fuel pumps provide significantly more pressure than others. Mine for example, sets the fuel rail high pressure code off quite often and ZZP had designed the fuel lobe on the cams to be smaller on the marketed ones so it wouldn't set this code.
Old Jun 14, 2012 | 05:17 PM
  #45
These pumps are a rare occurance though from what I've been told.
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
OPCrer
Sep 27, 2015 08:11 PM
