Shift 1-2, now throwing code p0300 and sounds terrible
Old Feb 10, 2011 | 11:04 PM
yamaha288's Avatar
the terminal thing? No if thats what your asking supposably it resets the ecu I dont know if it really works but thats the theory
Old Feb 10, 2011 | 11:18 PM
tomj77's Avatar
yup that thing is F'd
Old Feb 10, 2011 | 11:22 PM
efactor's Avatar
def you blew something in that motor. did you NLS before you got to the bagel shop or first started in the morning on a cold start when it happen?
Old Feb 11, 2011 | 12:49 AM
Zzcamaro00's Avatar
Originally Posted by xcross
they will fix it. make sure you disconnect both battery terminals and touch them together prior to the dealer
i dont post here often mostly just lurk.....but if i see something not correct....so ill just come out and say it...your a moron
that engine got some serious issues. i bet severely cracked or shattered ringland. rod....eh doubt it cause the noise complaint from the exhaust plus it would shake like it possessed
Old Feb 11, 2011 | 01:14 AM
xcross's Avatar
there is obviously something wrong with the motor dumb ass. I do not think it should of let go like it did with the way he described what happened and do think it should be looked at by dealer and i know the dealer will try to stick it to him if they can.
My car is modified and if i blew it up so be it, I will deal with it.
Old Feb 11, 2011 | 02:17 AM
Slobalt09's Avatar
dont disconnect the battery, it'll erase codes and freezeframe if there are any, but it'll also erase the readiness monitors which will lead the dealer to think you are hiding something major (tune) it'll be covered under warranty if you just take it to the dealer and tell them you were crusing and it started to make noise... i had a broken rocker sounded very similar, it was covered.
Old Feb 11, 2011 | 06:10 AM
gotboost?17's Avatar
Nothin Stock
lol sounds like mine when i blew the rockers....GL tho...but i couldnt move my whip
Old Feb 11, 2011 | 06:12 AM
Nothin Stock
just tell them u went ot go pass a couple cars and boom after that thats what happened ....fix now lol
Old Feb 19, 2011 | 04:10 PM
Sachemhockey44's Avatar
THE DEALER said it was two clogged injectors.................
Old Feb 19, 2011 | 04:41 PM
BooSSted's Avatar
Ummm, That's interesting.
Old Feb 19, 2011 | 09:42 PM
  #36
rukkee's Avatar
With all this fuel pressure I wonder how an injector get's plugged . Must have been some heavy duty **** that got stuck in there.
Old Feb 19, 2011 | 11:03 PM
  #37
80vetteL82's Avatar
Really? So was that the final outcome... a clogged injector? Definitely not what I would have guessed lol
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
