Should I get an oil catch can?
Old May 6, 2013 | 08:46 PM
JetLAGG's Avatar
I really just want to know if I should get a catch can? Car is tuned by byt apparently and when the tune is on, it boost at 24 psi making 314 hp/ 324 tq when intercooler and piping wasn't installed.
Also, should I just get it since I plan on hitting 350-360 later down the road?
All answers are appreciated.
Old May 6, 2013 | 08:56 PM
donkeyballs's Avatar
Here read this /thread
Why & where you should/shouldn't run an Oil Catch Can (OCC) on an LNF kappa - Pontiac Solstice Forum
Old May 6, 2013 | 09:50 PM
JetLAGG's Avatar
Well I do like having a piece of mind. Heh, I'll think about it.
Old May 6, 2013 | 10:00 PM
Powell Race Parts's Avatar
there is a long thread on LNF valve coking maybe a good idea to check that out.
Old May 6, 2013 | 10:28 PM
pretty interesting link, with some really good points. A catch can on the fresh air intake is a total waste of time and money though.
I kinda think that the discussion on here got a little more detailed and the mercedes benz link I supplied sure covers the issue of DI coking and rectification. Gone in 10 secs started that thread, a good one.
https://www.cobaltss.net/forums/2-0l...e-gunk-282355/
Recently, a month or so ago, Silvrred and now last weekend, Revolution , used an inexpensive air fed media blast tool with walnut shells ( recommended by most manufacturers, audi/m-b/bmw/toyota/vdub etc ) to clean the valves and did an excellent job for little money ( maybe 60 bux plus time and a new IM gasket)
it makes a lot of mess, you need to cover the engine pretty well. These two members really proved that with a little effort care and thought, a DIY solution is possible. Rather than replacing the cylinder head complete!
and of course to stop coking coming back, the issue of DI coking is well controlled by our PCV upgrade drain back oil seperator system.
Old May 7, 2013 | 08:38 AM
Don't waste your money on a catch can. Get Powell's PCV upgrade system, I have no oil in my intake or charge piping because of his system.
Old May 7, 2013 | 09:05 AM
axmonkey's Avatar
Can we get a link to the PCV Upgrade, I dont see it on the Powell site.
Old May 7, 2013 | 09:12 AM
armcclure's Avatar
You can't see hardly anything on the Powell site
Old May 7, 2013 | 09:31 AM
yellowsupercharged06's Avatar
just saying, powell has basically his own thread for all of his parts with pictures and prices .... search
Old May 7, 2013 | 09:57 AM
Sox-Fan's Avatar
Got Brakes?
https://www.cobaltss.net/forums/gene...powell-296456/
Old May 7, 2013 | 10:45 AM
r3v07ut10n's Avatar
BEFORE
[IMG][/IMG]
AFTER
[IMG][/IMG]
Old May 7, 2013 | 11:28 AM
Cobe's Avatar
before and after what?
Old May 7, 2013 | 11:35 AM
Sox-Fan's Avatar
Got Brakes?
Come on Cobe.......
Sir_Hiro's Avatar
Valve Cokin...Its a issue with DI Engines.
Old May 7, 2013 | 11:39 AM
Cobe's Avatar
Originally Posted by Sox-Fan
Come on Cobe.......
ahhhhh didnt put two n two together with the revolutions lmao Didnt even look at the users name clean as hell tho..
Old May 7, 2013 | 11:43 AM
Cobe's Avatar
no I understand this I just didnt know what he used for the before and after cleaning photos
Old May 7, 2013 | 01:36 PM
r3v07ut10n's Avatar
$60 for materials, 25 for gasket and 50$ for beer :P
For you Americans
Portable Abrasive Blaster Kit
25 lbs. Coarse Grade Walnut Shell Blast Media
For us Canadians
50 lb Walnut Shell Blasting Abrasive | Princess Auto
Siphon Feed Abrasive Blasting Gun | Princess Auto
Old May 7, 2013 | 02:32 PM
QuickSilver_SS's Avatar
Originally Posted by r3v07ut10n
There is a princess auto close to me. I wonder if they sell the items in store or do they need to be ordered online ?
Old May 7, 2013 | 02:58 PM
Lol americans can do it with 25 lbs of walnut shells. Canadians need 50 lbs. Thats because Canadians dont use a vacuum, they use more and then they simply tip the car upside down and shake off the excess...
Old May 7, 2013 | 03:45 PM
r3v07ut10n's Avatar
my store had them in stock but in the back. Make sure to ask, because somebody that worked in the store was allergic!
I only used about 5-10 lbs or so MAX, and used 85psi on the gun.
Old May 7, 2013 | 07:03 PM
Did you use the tip that came on the gun ?
Old May 8, 2013 | 09:59 AM
axmonkey's Avatar
Instead of catch cans etc. If you don't care about pollution controls, can you just bypass the whole PCV system and just vent to atmo? Wouldn't that keep the valves clean?
Old May 8, 2013 | 10:41 AM
armcclure's Avatar
Can you? Yes. But the main purpose of pcv isn't emissions....
Old May 8, 2013 | 12:33 PM
axmonkey's Avatar
Go on...
Old May 10, 2013 | 01:57 PM
r3v07ut10n's Avatar
Yes all stock stuff that came with everything.
