should i keep it or sell it
Old Mar 24, 2013 | 08:37 AM
huckernage's Avatar
here my tc
my mods so far:
but i buy part for AMQ performance and look what i got:
will I like injen Charge pipe, IC zzp and a flywheel or i should sell it
Old Mar 24, 2013 | 08:41 AM
Wert842's Avatar
You already have thm so just put them on! The charge piping is more for reliability reason and basically the samething as the IC. You really won't feel a difference in the flywheel though.
Old Mar 24, 2013 | 08:46 AM
huckernage's Avatar
i hope i ll feel it. a lighter flywheel should help faster rev up NO?
Old Mar 24, 2013 | 08:49 AM
Wert842's Avatar
Pretty sure I read somewhere that our stock flywheel is already decently light compared to others. But then again I could be worng.
Old Mar 24, 2013 | 09:00 AM
huckernage's Avatar
anyway part has been give to me by Eric and his HHR ss ZFR. he ll install it for few $.
i want to see Rose with all those part and get low torq and mid. i like pull in third gear and fourth.
with Charge pipe hot side and IC, should I boost quicker?
on this video i was stock with TFT selected. power is already very good. but like everyone else, i maybe want more hahah.
Old Mar 24, 2013 | 09:06 AM
Wert842's Avatar
Like i stated before, the charge pipingand IC are more a reliabilty thing. The plastic one can crack under high boost and a new one will prevent that. Samet thing with the IC. The IC has plastic end tanks that actually have blown off. Both of these can cause boost leaks and that's the reason for these replacements.
If you want more power move onto meth, E, cams, turbo, or a more aggressive tune.
Old Mar 24, 2013 | 09:12 AM
huckernage's Avatar
cams ohhhhhhh boy. if as 2.2 stg2 cammed idlling trouble no merci.
zfr is a option when eric ll sold his kit
meth i dont trust that because the system can fail.
more aggressive tune wont be a issue to get. but need a clucht before a aggressive tune.
thx for your help Wert
Old Mar 24, 2013 | 09:27 AM
Wert842's Avatar
Cams from ZZP are actually pretty decent. Really haven't heard anything bad about them other than they work and do what they are intended to do.
Zfr or a bigger turbo will always net you more power regardless and are definitely happy time makers.
Meth is quite reliable if you run the right system and make sure everything is always running right. Aem makes a really good kit that allows you to monitor the kit and lets you know what's going on.
For our cars and tuning, a clutch is always something good. I was tuned on my xcar for 8k miles and just at the end of summer my car started slipping bad. Then again I track my car a ton and that really isn't good for the clutch.
No problem man!
Old Mar 24, 2013 | 05:35 PM
huckernage's Avatar
what is the easiest way to remove a charge pipe?
from under the car it is a PITA
do i need to remove the bumper?
Old Mar 24, 2013 | 05:47 PM
Wert842's Avatar
You'll have to remove the splash guards on the bottom of the car to remove the majority of the pipes.
Old Mar 24, 2013 | 08:49 PM
Kyle09TC's Avatar
just the 2 clamps and 1 screw and pull it out from the top. i never had to pull splash guards off however you will have to remove the bumper for the intercooler so might as well do both at the same time. the bumper off may give you more room but you dont have to take it off for the charge pipe its like a 20-30 minute job max
Old Mar 26, 2013 | 10:30 AM
huckernage's Avatar
negatif square head
the acces for the lower clamps is to small. maybe you have girly hand to get there. but mine are not that girly.
Old Mar 26, 2013 | 10:54 AM
CudaJoe's Avatar
look at that sexy model
Old Mar 26, 2013 | 02:38 PM
huckernage's Avatar
rose is as sexy as ours. yellow one are rare and sexier than a gray one
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 21, 2015 11:57 PM
Oct 20, 2015 09:56 PM
Trav3480
Sep 28, 2015 02:46 PM
grampss
Sep 27, 2015 08:51 PM
