Soft brakes at 24k?
The rear caliper piston is self- adjusting, so yes there is a self-adjuster on the rear brake system. The simple, cable-actuated lever is integrated to a self-adjusting piston. For those adjusting their e-brakes at the base if the handle, make sure the pistons are clicking out as the pads wear. Otherwise, you'll have more piston travel as the pad thickness decreases, causing more e-brake handle travel as well.
wet rotors, crappy pads, or the brakes got so hot that the fluid boiled at created air in the lines
my pedal is hard, i like the brembos because the pedal is harder and has good feel. not like honda brakes.
