Soft brakes at 24k?
Old Oct 26, 2012 | 12:06 PM
mkulrey13's Avatar
There is no recall on the brakes.. There is a TSB about the rear but thats it.
Old Oct 26, 2012 | 12:15 PM
prevsrt4owner's Avatar
Originally Posted by sdmws6
The rear caliper piston is self- adjusting, so yes there is a self-adjuster on the rear brake system. The simple, cable-actuated lever is integrated to a self-adjusting piston. For those adjusting their e-brakes at the base if the handle, make sure the pistons are clicking out as the pads wear. Otherwise, you'll have more piston travel as the pad thickness decreases, causing more e-brake handle travel as well.
Perhaps things haven't changed from last year.
Old Oct 26, 2012 | 09:03 PM
kzak104's Avatar
wet rotors, crappy pads, or the brakes got so hot that the fluid boiled at created air in the lines my pedal is hard, i like the brembos because the pedal is harder and has good feel. not like honda brakes.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
